Have t67 25g on 6 boost with tial 44mm gate on fully std 25de+t all suporting mods needs a tune should crack 400. Ill post up sheets when tuned
fully standard, crack 400, what?
your on crack.:rofl:
  • 3 weeks later...
and finally my build is reaching its end
r32 coupe
rb25de neo
t3/t4
440cc inj
sard frp
wasted spark conversion (no more coil problems ever!)
walbro 255 pump
38mm external gate
3in thick huge intercooler
50mm bov
3" exh
z32 afm
z32 ecu rewired for inline 6 and vct (for the neo engine)
run in tune was on std injectors/afm, 200rwkw@9psi
getting retuned next week with the 440's and z32 gear, vct and more boost, shooting for 230 with better response.
other mods
hsd adjustable suspension
r32 gtr brakes/hubs
r33 gtst lsd
hicas lock bar
carbon kevlar unsprung race clutch 3000lb pressure plate
sad rb20 box
half cage
terrible paint
  • 3 weeks later...
  • 2 months later...
  • 1 month later...
Made 196 rwkw at 8 psi on Creatd Motorsports dyno today. Tuned by Rob at Creatd, exceptional bloke to deal with and very happy with the tune.
Relevant mods:
-Stock un-opened RB25DE engine, head, intake and airbox ~175,000kms
-Stock R33 GTST injectors, rail, ECU, exhaust manifold
-stock R34 GTT turbo
-Hybrid 600X300X76mm front mount intercooler
-custom 2.5" intercooler piping
-custom metal intake from AFM to turbo
-JJR 3" dump/front pipe
-Custom 2.5" high-flow exhaust, cat and mufflers
-Yellowjacket Coil-Packs
-NGK Platinum plugs gap
-Walbro GS-341 fuel pump
-Turbo-tech MBC
-Apexi SAFC "blue-screen"
-Oil cooler kit with filter relocator and thermostat
-Nismo adjustable fuel pressure regulator
  • 4 weeks later...
Pretty good results guys, this is one of our drift cars built on a limited budget, survived two seasons in D1NZ plus specialty events, before it dropped compression on number one cylinder, we replaced the entire engine with another StageA RB25DE with around 70,00kms (nicely run in)and back to banging the limiter. $300 for the engine, cheap as chips and easy to replace, I would not go to another rebuilt engine unless it's a VK56.
It's all in the tuning.
Model - R33 GTS25T
Engine - RB25DE
Modifications / Parts Used - WGC34 RB25DE Engine, unopened 140,00kms. DSR 3540 Turbo, 800cc injectors, FFPlenum, with standard turbo throttle body, SS Top mount exhaust, 3" Turbo back straight exhaust with cannon muffler on the rear 5" tip, 44mm wastegate, 1 bar of boost
Engine Management Used - Plug in G4 Link, Tuned by Shred Motorsport
Fuel Used - Alcotane E85
Boost Used - 1 bar
Dyno Tune Results
Power- 479HP/357kw @ 7056RPM
Torque - 492Nm @ 6000RPM
Misc- use engine from auto car any RB25DE will do
Costs - Parts: $4k Labour: $by self Tuning: $sponsored, Dyna Pac Hub Dyno
Dyno Graph
Edited by 0t1
Well, thought I should put something in here. Thought it was rbs but I saw a few cas too, so why not add mine.
VQ35de in a m35 Stagea. Awd. Hks z33 turbo kit with some tweaks. Gt3037, 60mm external, 600cc, walbro, tuning with uprev, by DVS Jez.
It's got about 200kw atw on a bit less than 6psi. Not super powerful, but it's a big ass wagon, and that's fun. Pretty much no lag whatsoever, as you can Imagine with 3.5 litres!
Forgot about the template sorry. Mods please delete my other post?
Model-1994 R33 Series 1 coupe
Engine-Stock un-opened engine, ~175,000kms at time of tune
Modifications / Parts Used- Stock GTS head, intake manifold and airbox
-Stock R33 GTST injectors, rail, exhaust manifold
-Anything not mentioned is stock GTS or GTST
-Stock R34 GTT turbo ~70,000kms
-Custom 2.5" intercooler piping
-Custom metal intake from AFM to turbo
-NGK Platinum plugs
Engine Management Used-Apexi SAFC "blue-screen" with stock GTST ecu
Fuel Used-BP Ultimate 98 RON
Boost Used-Peak of ~8.5 PSI
Misc-No boost controller, just restrictors in the wastegate feed line.
-Needs a decent ECU to hold timing properly, will smooth the curve out and make a touch more.
-3" exhaust and boost controller may help the 6000-7000 rpm range hold more power.
-Car previously made ~140rwkw with basically the stock turbo set-up bolted straight on. Ran this way for a year with no problems.
-The dip in the graph at 115-125kph is apparently the ECU changing timing and fuelling for the stock solenoid to raise boost pressure, as the car doesn't have the solenoid it changes the power.
-Best part is stock GTS peak power at ~2800rpm, stock GTST peak power at ~4500rpm very responsive and fun to drive. Holds 170+rwkw for a full 2000rpm.
Dyno Tune Results-196rwkw@5800rpm
Costs-All up for relevant stuff, including turbo conversion and tuning roughly $3000. Labour I do myself. Tuned by Rob at Creatd Motorsports :thumbsup:
Edited by blk94r33
I ran this engine in my Cefiro Drift car for two seasons plus specialty events, the only problem was my final drive gearing was a bit too high for some tracks, I was using 4.3:1 locked diff.
Model - A31
Engine - RB30 with RB25DE head
Modifications / Parts Used - R31 RB30E Engine 240,000kms, RB25DE head . DSR 3540 Turbo, 650cc injectors, FFPlenum, with standard turbo throttle body, SS Top mount exhaust, 3" Turbo back straight exhaust with cannon muffler on the rear 5" tip, 34mm wastegate, 1 bar of boost, relocate cambelt tensioner, RB25DE oil pump,
Engine Management Used - Plug in GTS Link, Tuned by Shred Motorsport
Fuel Used - BP Ultimate 98
Boost Used - 1 bar
Dyno Tune Results
Power- 404HP/302kw @ 6243RPM
Torque - 500Nm @ 5468RPM
Misc- use engine from auto car any RB30E will do
Prevous setup was with T3T4 and standard injectors and 265rwkw can't find the dyno pic?
  • 4 months later...
From last tune added:
Z32 Nistune ECU
Customized Cooling Mist WMI kit (see "let's talk water methanol injection" thread)
NGK BCPR7ES' gapped to .8
Boost wound up to ~9.5psi
Red is the stock ecu/SAFC combo, different dynos, conditions, times and probally the ECU being weird resulted in 166rwkw peak on this dyno.
Green is with the above mods, WMI de-activated.
Orange is the current tune with WMI and a few minor tweaks, if the WMI dies the engine should still survive rather than relying %100 on the WMI kit.
Massive +1 for Cat and Trent at Chequered Tuning, exceptional people to deal with from the get-go and i'm exceptionally happy with the tune and their awesome customer service. What the graphs don't show is the rest of the tune: on-off throttle, part throttle feel, anti-stall, fuel economy etc. Car is completely different to drive in every way.
  • 4 months later...
They are pretty much the same box as the RB20DET, and will handle stock power happily and anything upwards of around 200rwkW safely if not abused; If you want to clutch drop/clutch kick/flat shift it will not last long at all at that power level.
  • 7 months later...
Few changes made from last time (tune related only listed):
-Turbo hi-flowed by Hypergear, 12 psi actuator
-Fuel pressure raised to ~50 psi, stock injectors at ~90%
-Full CES racing 3" exhaust
-Larger oil cooler core
-40mm alloy radiator'
-Gates racing timing belt
-New water pump
-Went from a 250cc WMI noizzle down to a 180, pump pressure back up to peak of ~220psi.
-Did 5 stud conversion, more suspension work, new WMI tank etc. but most stuff is the same.
242 rwkw and 400 nm on ~15 psi.
AFR and torque, stock turbo at ~10 psi vs. hi-flow at ~15 psi
Power and torque, stock vs. hi-flow
Safe tune no WMI vs. WMI on and minor tune changes, awesome results for a VERY cheap and reliable (18+ months now) kit.
And another very happy Chequered Tuning customer. Could not be happier with their awesome customer service and another great tune. Cheers guys!
Edited by blk94r33
  • Like 1
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
