Thought I would throw up a few pics of my completed SR20 build - no dyno yet (finished at midnight last night).
Interesting bits:
Full-Race Twin Scroll mani with twin gates
3071 with .78 divided ex housing
Hypertune Intake
1000 cc Sards
Autronic
Forged and Darton Sleeved Bottom End
JHH Engineering Head with larger Super Tech inconel ex valves
Tomie 260/260 12mm lift pro cams
Pic of the gates before the dump tube went on - these actually merge back into the main exhaust.
Edited by juggernaut1
https://www.sau.com.au/forums/topic/249832-my-sr20-build-pics-inside/
  • Replies 81
Damn sweet looking setup. Cant wait to see a power figure. As much as im enjoying my 26 i miss my SR's...
Why the twin gates?
The manifold and turbo exhaust housing is divided (i.e. twin scroll). On a SR20 this means cylinder exhaust manifold runners 1 and 4 are paired off and completely and separately to 3 and 4 right up to the exhaust wheel.
Because they are paired off each pair of cylinder runners has its on gate. Whilst it is possible to use a twin gate tubes merge into a single gate - there is a cetain amount of exhaust gas pressure leakage from one gate tube to another in the exhaust manifold as it is not possible to create a perfect seal between the two gate tubes at the merge point just before entry into the single gate.
with a setup that well designed for boost control, I would have thought you would have optioned for at least a GT3076 (6 blade version) ?? Not knocking it, but that turbo will produce sub 300rwkw outputs, but a good mid range.
Just think thats a bit of an overkill for hte powerlevel you are going to achieve.
Well done none the less, don't take my comments as slander, just more curiosity.
Jono
Edited by The Mafia
Jono
No offense taken. I actually did consider the 3076 but Geoff Raicer from Full-Race convinced me otherwise and advised me this setup will acheive quicker lap times on a short circuit like Barbagello in Perth where I live. I seemed to get the impression from him that the slight loss in transient response wasn't worth the extra hp gain the 3076 would give.
In any case, I wasn't chasing any certain power level more a case of the best transient response and area under the curve.
awesome setup, good components with a well thought out plan ad application. So often i get cars dropped off that are based on the hp rating of the turbo and not the application.
We did a S15 earlier this year to achieve similar things (you probably know athid) decent plenum, decent turbo setup, cooler ecu etc and well it produced the craziest curve and torque i have ever seen outta a SR20, i cant wait to see your dyno grpah as im sure they will be very close.
here is athids;
Edited by URAS
Yes Trent it will be interesting to see how it compares to the single scroll stuff. Can't wait to get it on a dyno, tune and run it in.
i reckon your a winner for sure, beau's setup on the beams engine sure aint a slouch :P
  • 2 months later...
Quick update
Had the car on the dyno yesterday.......ambient temp was 43 degrees and high humidity here in Perth so it was working hard......anyway at 17 psi the Hypertune intake manifold split open.
Couldn't see it (or hear it) at first but couldn't get the car to idle at less than 3000rpm so we new we had a leak after the throttle body as we checked all hoses etc.
Pulled it off last night and the intake had gashed open where the idle control valve outlet is (which is underneath the manifold). Would have thought these manifolds could have handled alot more boost.
Anyway will weld it up and put it back on the dyno..........with more boost.......hopefully.
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
