I understand Ricky from Billet Turbos fame makes divided manifolds on a request basis (under the guise of Fantasy Manifolds) and has been doing so for quite a number of years apparently.
Also I spoke to Kyle at 6Boost about the prospect of making a divided manifold before I bought the Full-Race mani. I only went with Full-Race because the $A was $0.96 at the time (so the the price of the kit was half reasonable) and that it came as a complete kit i.e. I didn't have to separately source the divided ex housing (which I guess could have ordered through ATP) and down pipe (could have been custom made), v-band flanges, twin gates etc. Also Kyle had suggested to use the dual gates for true twin scroll on the SR setup even before Full-Race had started making them.
  • 7 months later...
  • Replies 81
There is one option no one seems to have looked into and that's using the big frame diesel GT35 T4 flanged twin scroll twin integral gate (TWIG - twin wastegate internal gig) housing and fit a Garrett GT3782R into it .
Sure it means profile turning a GT35 turbined housing to suit a GT37 turbine , which just happens to be in 78 trim instead of the 35's 84trim , but may be workable .
That would get you T4 flange/twin scroll/twin integral gates/a big frame turbo with the same compressor wheel as a small frame GT3582R - and in a REAL GT40 compressor housing - not the T04S one .
IMO the GT3582R is too much Bitzer , spin off from the HKS spec "GT3240" which had the turbine cropped and the comp wheel in 54T instead of 56T .
A .
These are the only dyno's I have re the tune which as you can see were done a while ago. The tune was never completely finished because my tuner was borrowing a dyno on the day and ran out of duno time. Also need to fix up the boost drop in the top end. Note the ambient temp was around 36 degrees when these were done. I have had it on another dyno since in cooler conditions and it made a couple of more psi across the board at the same rpm - for instance it was making 26 psi by 4000rpm - no printout to show unfortunately.
This dyno done in 4th gear - (5th is 1:1 in my car as I have a 6 speed close ratio Nismo box):
Same dyno as above overlaid onto a different s15 with single scroll 3071 ex gate on 6boost manifold 256/256 poncams and stock intake.
This dyno done in 5th gear (1:1) after retarding the ex cam a couple of degrees - picked up more low and mid and lost top end - revved to 8,000rpm although shown in klm/h. I know the scaling is crap on the horizontal line. One day I will get a better printout. Going to try a 3076 and I have a 205 litre drum of E85 sitting in my garage. However, lost my licence for 6 months under WA's hoon laws (yes in this car) so not being able to drive knocks back the enthusiasm a bit to get it done. :(
Oh...and an update engine bay pic.
Edited by juggernaut1
looks shmick juggernaut. is the the highest power you have made so far?
i just fitted my 3071r t28 flange .86 56T, running a GK tech manifold modded for external gate, and running stock inlet.
cant wait to get it tuned with my solid 260 12mm tomei cams. hoping to make some numbers close to yours.
DVSJEZ
Well thats the most power that its made that I have evidence of......which was the day of its initial tune after the motor was run in - but I'm sure it makes more power on a cold day/night....as any turbo car would :thumbsup:
Actually I tell a lie - it made around another 10rwhp when the ex cam was straight up which was then retarded a couple of degrees.
  • 3 months later...
Nice build. We are undertaking a similar twin scroll set-up at the moment.
In regards to the wastegate vacuum lines, it looks like you are using a boost controller and thus utilising both the side and top ports of the wategates?
I take it you have run it like this (using GReddy Profec B Spec II solenoid as an example):
1) plenum -> boost controller.
2) plenum -> solenoid (NC)
3) plenum -> solenoid (COM) -> T fitting -> top port of each wastegate
4) plenum -> T fitting -> side port of each wastegate
As this would help provide pressure on the diaphragm to keep the gate shut, instead of just relying on the spring.
  • 3 weeks later...
OK so my car is now at C-Red for the turbo and exhaust upgrade. They ran it on the dyno to get a base hp figure before the upgrades. I get a call from C-Red and they make the comment that the car has an excellent and progressive power curve for street and circuit duties, and that the power delivery is typical of a 6 cylinder.......and that they wouldn't change a thing including the turbo!!!
So now I'm in a quandry what to do.....Lol.
Don't worry Dane, you'll get the 3071 turbo. :thumbsup:
They also picked up that the 3071 turbo was slightly surging as it came onto boost which is what I always suspected as the twin scroll setup seems to spin the compressor early in the rpm range....and which is why I was leaning towards the 3076 with surge ports as the logical upgrade. Another solution would be to advance the exhaust cam - when the car was initially tuned we retarded the ex cam a couple of degrees to give more low end at the expense of some top end.
Also before it went to C-Red I also changed the diff ratio from 3.69 to 4.08 and the acceleration is insane. I did keep the stock diff in case I need to revert back for improved traction.
PSI Parts.....my boost lines are referenced to the compressor....and not the plenum as suggested by you.
Will post up developments as they arise.
If you have a look at ATPs site they are now selling twin inlet GT30 turbine housings in from memory 0.82 and 1.06 A/R ratio .
If I was going to do another turbo I'd think about a GT3076R and give consideration to the 52T version . You don't necessarily have to use the port shrouded compressor housing on a 2L four cylinder particularly if the turbine housing ratio is up there .
I don't remember what size your exhaust was off the turbo but if it'll fit 3.5" would be good - need big pipes for the first meter or so off these turbos IMO .
A .
Disco,
I have both the 3076 52 trim and a 3076 56 trim turbo's at my disposal. I was going to opt for the 52 trim.
I had the .78 housing extrude honed in the states...but I am still waiting to receive this from the courier. The .82 and 1.06 came out after the housing was extrude honed....bugger.
Yes I have a 3.5 inch exhaust to go on. Will need custom 3.5 inch dump pipe to be made up....currently 3 inch.
Noice
Don't worry Dane, you'll get the 3071 turbo. :ermm:
:thumbsup:
Great to hear that C-Red think so highly of the setup, bodes well for the use of it with a 2.2 me thinks, unless the surging issue becomes a problem.
But I'll be really interested to see how you go with the 52 76R. Who knows, we may end up swapping turbo's at some point! :bunny:
Dane, you will love it....if its great on a 2 litre it will be fantastic on a 2.2. IMO surging will be less of a problem on yours as you have bigger cams and bigger cylinders. As previously stated I have ex cam adjusted for better low end too which may have contributed/caused the issue.
I'm positive I will Ian! :ermm:
I actually had my surging mixed up in my head just then, thinking it was too much efficiency in the engine for the turbo, rather than the other way around :thumbsup: Funny, last time I checked I wasn't blonde!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
