For it to be closed loop it will need a signal input from the camshaft position sensor that you will need to install. You can't just use RPM as an input for closed loop as it's unrelated to what you are adjusting
I thought he was talking about open loop control, but yes if closed loop you obviously need an input as well.
We are looking into an rpm box for you guys.
I've been using the msd rpm switch for a while now... sturdy bit of gear.
I'm suuuper keen to get a hold of 25 VCT conversion parts and camshaft from you once it's all sorted. I'm suprised no one has developed it yet???
Do greddy still make the adjustable cam sprockets for the 25 vct cam gear?
sign me up-
Cheers
Justin
I'll look into that thanks.
The factory RB25 inlet gear is adjustable....it's just on the back of the gear :(
I have seen someone do a bolt configuration through the gear so it was adjustable from the front.
The MSD RPM switch looks like it only turns something on at a specific RPM? We need to turn it off again at a certain RPM so that means it would need to be programmable
Look for a MSD RPM window switch, a RPM Switch is on... A window switch is on and then off :)
I'm just using a on switch mind you, works fine
Thanks.
They seem to be what we were looking for. And only about $150 so also the right price.
what intercooler, are you running??
His car has the basc 70mm ARC GTR intercooler. They're a good bit of gear. Light, good flow and good cooling. They are actually lighter than a stock GTR intercooler!
i was pointing more at v8 vvt that run 4 cam sensors
like the bmw's and soon to be nissan v8's
run them as pairs in/in ex/ex not often you want different valve timing event between left and right banks.
Thanks.
This is what I use:
http://www.msdignition.com/Products/RPM/Timing_Controls/RPM_Controls/8969_-_Digital_RPM_Window_Switch.aspx
Cheers :cheers:
J
Woudn't trust a eboost to switch anything on, they are a POS at the best of times
cheers
darren
Mines works great, what is the issue you have with them?
Controls boost well, window switch works great, lots of people recommend them?
I've never had problems with the unit or the solenoids on, only the people who wire them in incorrectly. I'd say most people's grief would be caused by the same thing
They have a bad habit of just locking up , outputs stop working at same time and you have to send them back and get them updated.Eboost 1 and 2 do it. ... I am not the only
one who had that problem, a mate had the same problem , and if you look around, a lot of the sport compact racers have had the same problem
Its actually quite common and a lot of workshops won't use them for that reason, as i found out after mine f**ked up.
Not good when its hooked up to your water injection solenoid that for sure
I wound't buy a second handy of ebay, thats for sure!
When it worked it did do a awesome job of boost control, funnily enough mine got stolen out of my car when some work was getting done to it, before i had a chance
to get it updated, hopefully it blows the thiefs car up ..lol
cheers
darren
Edited by jet_r31
i've got 2530's, which are almost identical, and with baby cams still managed 400rwkw with E85, only 21psi as well - most people run 260 cams, and prob more around 24psi is the pistons/everything else can take it, you'll walk in the 400 with -5's :)
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
