how come it's got such a good spread of power??
what's been done to this, i havent seen a power curve like that for a turbo motor before?
What's been done? Alot! It even has a standard airbox! :nyaanyaa:
Note that crappy brown line is GT RS's. The red line is -5's. Boost controller is still off with the -5's. It seems with the modified actuators the controller on it doesn't like it. It would have been nice to hold 25 PSI the whole way but meh, its all good. It wont be the last time its on a dyno. I haven't driven it much, although as Steveo said, 265 Semi's and it turns them just rolling on the trottle in second. Turning tyres DOWN a hill is interesting also! I had a choice of backing the intake cam off for the 450 ish run but I was after area under the curve. What is interesting is taking off from lights without being an idiot. You don't realise how easy you pick up speed!
Really? How? it has a 3.5-4k spread of useable power, lots of motors have this? Albeit often not as nice as this it has certainly been done before.
It's easy to get that spread with much less power, not as easy with 400+ kw. Remember this is the 400kw plus thread, we do things differently in here. A huge spread of power in the 300kw thread is a piece of piss
Exactly. Confused as to how you'd not realise how awesome of an achievement it is.
Comparing to a RB25/300rwkw setup, pointless.
I take it your not using pump E85 ...are you using a zeitronix to display the E content ?
Yeah mate, straight out of the pump nozzle. Yes I am using the Zeitronix display. I actually got E77 from Rozelle a few weeks ago and have seen E89 or E90 from the same pump a few mponths before. Shows how much it varies.
Nice result!
Ethanol changes the game a lot :)
Must be very shitty or very cold r-comps if they are spinning in 2nd
Well i went for a 15 km drive before that and I was about 5 km into the drive where it did it. I dunno. Either way, laying fat lines is cool :D
    • Also seen this as an option
    • I get you, we’ll see I’m aiming for 200ish kw now and hopefully 300rwkw down the line after some upgrades maybe like headstuds, E85 flex fuel etc  so trying to make it final for that now, I can get a GTT airbox for $280 so it’s not too bad but not sure if there’s better ways to spend that money. I seen online they say pod filter which isn’t enclosed isn’t good especially for a plus T.      hard to say what to do
    • Meh. How much power can you make from a +T anyway? I wouldn't have though it would be enough to challenge the airbox. It's not as if it's tiny compared with the turbo one. As to putting a pod in a stock airbox .... it's not the filter element that would be restrictive. It would be the air inlet to the box that would be the narrow point, which you could open up regardless of what element was inside. On my R32 I opened up the sort of triangular opening in the bottom front corner of the box, deformed (heated, moulded) some 4" stormwater pipe to fit to that opening and punched a 4" hole down through the inner guard to the spot where the stock intercooler used to be. This was purely in the search for a cold intake, but you could do something similar if you need to open up the inlet side of it. The AFM tube size is the same for both NA and turbo, so the outlet from the airbox is same same anyway. If you're going to do the right thing, then an aftermarket ECU won't care about the AFM (ie, you can get rid of it). But even if it was still there, people pull >300rwkW through them all day, and I suspect you won't be going there.
    • R34 RB25de Neo by the way ^
    • Doing a +T on my car and I’ve read the precious forums lots of mixed reviews from sometime back.  checking if anyone has any ideas for airbox or enclosed pod filter or solutions?  I was thinking stock GTT box but some say it’s restrictive? I seen some people try fit in a pod in the box anyone done that recently?  not any good enclosed options ? Thanks
