no idea... by asking the question i'm guessing not all manufacturers use the same measurement? ie, some use OD and some ID?
but don't we always just refer to 3"/3.5"/4" exhausts? i'm assumed that was always the OD?
if theyre the ones pictures then ive got a set (theyre ti too) and they are 80mm into a 90mm outlet
oooo... got a clip you could throw up by any chance/?
Best way to figure out what you would need is calculate your required flow and run it against varying pipe diameters.
prob getting a little technical for me, but i can give it a crack. How would one go about doing this? :D
this front pipe looks to be the same configuration as my veilside full system.
i.e. my front pipes collect into a 90mm main pipe BUT mine is mandrel bent SS (not lobster back TI).
look like merge to 90mm, not twin 90mm
soooo sexy.... :D
Pauly DIemar is actually making some front pipes these days, equal length and merge into 4", out of stainless... just under the four figure mark in price too!
Man of many talents.
If only I could order one
Edited by jangles
I made a my tuned length front pipes out of mild steel, 3inch into 4inch merge.
The welds Arnt as pritty as the race pace ones, cause I use a mig. But once they all heat wrapped you don't see any welds or anything. Cost me around 150 bux in materials. And a day of my own time.
I'll post a pic tonite of them before being painted and wrapped. Can't do it now as I'm on my phone.
There for me :-)
There a twin 2.75" into a 4" merge, but the design could easily be modified into a twin 3" to 4" system.
577awKW
RB26 @ 2 BAR
GT4088R 1.06 ar Full-Race Twinscroll Mani
Kelford 280 cams Fully ported Head
Greddy intake plenum
Vipec ECU
ID1000 injectors 2 bosch 044 pumps
many more looking to upgade ignition so i can run more boost currently running superspark coils and they are not cutting it
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
