when i was using Caltex, they were bang on E70 the whole time (except for one batch in the dead of winter being bout E65)
which reminds me, i need to check with Caltex if they've switched to 85% - you could always buy a sensor, not run flex-fuel but just use it as a monitoring tool.
hahah, yeah that's true. just buy straight ethanol and mix yourself! :D
but for normal tunes, a variation of E% a few in either direction isn't going to make a difference. Don't think Trent has anything smaller than a 5% change resulting in any timing/fueling change on my maps
  • 5 weeks later...
The turbo is still 600hp rated though, now matter what CR you have.
The only way to make that power with a 35 frame is if it is a hybrid, like a 3566 or similar with a big A/R and judging by that dyno graph it would have to be because that is a laggy curve for a 35R on a 3L.
Even still, 500kw Thread: ACCESS DENIED.
It's a GTX53R not a normal GT35R so it does flow another 70odd hp more...
In saying that the results are a little eyebrow raising and also don't fit into this thread
Well last time you posted then 490rwkw result you only ran 136mph... :merli:
Time to go back to the strip and see if you'll actually get near 140mph, they be the results we wanna see
Either way it's not 500rwkw - so have moved the posts to the 400rwkw thread.
  • 1 month later...
car was making 431rwkw when i ran 10.8 @ 138 MPH
i have since gone to a new tuner and hence new results.
U know who micks motorsport is?
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
