  • Replies 2k
just dropped the r30 at the elicticans, would you believe it the only other car there was this stunning all black r32 gts-t running an rb25det, sweet looking beast, front and rear gaurds were flared or made to look like a gtr. Phat.
on the topic now, hope to get the car back soon with all the things fixed, lights, tacho, boost gauge all these thing were not finished as i had to take the car to get the suspention finished as they needed the car to run to do the work. also by the time its finished the parts from gus should be here so thats one more thing out of the way!
Hows it going guys, just thought i'd let you know how my rb25 conversion was going. well the old engine came out pretty easy. Now im just searching for an R31 xmbr, mounts and brackets to bolt the RB25 too. everything else isnt going to bad, clutch master cylinder was simple bolt off bolt on. However with brake booster, you have to drill out the firewall a little to get the new one to fit. no biggy. other than that im now just trying to track down some magna discs and calipers because apparently they bolt up to skylines quite nicely (only r32's and onwards though). we'll see about that though.
hey guys im currently trying to add some mods to my car and was wondering if anyone had any pics of the mods they have done and instructions on how to do them... all help would be appreciated as im only a newbie with limited experience with cars... btw my car is an 82 skyline hatchback with the l2.4e engine..
yeah we've lost about 3 pages of info, alot of good stuff, trying to think of where the oil would come from, have you looked underneath for any oil spray, as the only thing i can think of is the gear box as thats the only thing with oil in that area?
I just bought a turbo R30 ES and it's really sweet man!! I was looking into upgrading it a bit and was wondering what i can do that is practical and affordable tuning. It's got a GT-R exhaust on it already and a bit of CAM work but it is only runing standard boost and i want it to be around 200-250 horses. Any ideas? :D
Chu-rulz- firstly, are you going to stay with the l24e or look for something more eventful. if its anything to you, i have a ti hatch, now there not a bad place to start, they are not that power producing unless you spent big dollars. but if you want to start start with plugs, leads and filter, use a good fuel system cleaner every few tanks, then its exhaust, a custom set of tuned extractors will always help, get rid of the final muffler something a bit more sports like 2.25/2.5 inch system, theres a good start or just put in an rb20det and not look back!!
r30-turbo- i guess you are running the l20et engine? the only other things i can come up with would be maybe a bottom end swap for the l24e then big turbo, ecu chipping or swap?? for that power may cost big dollars as i mentioned to chu-rulz, a mate has a pual newman version with the l20et and is running 22psi with no intercooler and is getting around 200hp at the flywheel, the paul newman version is a slightly higher rated engine though,
rsx84- i am looking at sticking with the l24e at the moment until i got the dough for a bigger engine. it already has a huge custom tip on the exhaust. i am about to do the plugs and leads, i also want to modify the air filter but i dont know how... also where would i get extractors from?? btw im in newcastle, nsw
R30_Turbo welcome to the club bro!!! Its a very good club to be into!!! Whats done to your car?? Its an HR yer???
This friday, turbo will be in operation, well the oil lines will be done, and all the hoses and fittings will be ready for the water lines, then its a case of hooking it all up, and getting a dump made for the tubrz and thats that side of it done...Then pipe work to go and PARTS!!!
BTW the wheels look swoite as on the car, if i can find somewhere to host them, i'll put a link up for yas!!!
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
