Uploading some results posted from a NZ fan today. I think the NZ dyno HP determination equation is in DIN.
Latest ATR43SS2 internally gated bolted to the factory manifold on S2 RB25DET.
- Greddy knockoff plenum
- 1000cc xspurt injectors
- 80mm bar and plate intercooler
- custom 3" piping
- g4 plugin ecu
Final numbers were 331kw @ 500nm at the wheels on 18psi boost on
  • Like 1
Hey Stao
What can you do to my old ATR43G2.5 -> Which was sent back to become a now SS2 a year or so ago. if u remember.
Is it worth sending back for some loving?
Im making a healthy 300+rwkw at the moment.
Can you get that close to your atr45? or is the housing to small for that?
Want some extra juice for Racewars next year :P
Yes can upgrade few things to make more power. I can't remember what configuration it might be in. Best email few photos first.
Cool cheers, have you got a handful of atr45 install photos? Wouldn't mind seeing the intake setups on r33
Hi Michael,
I have this turbo on my R33 - I'll post some pics below. If you want anything more specific let me know and I'll go pull the airbox off for you
F4591ECD-F6E9-491C-A7C4-5B795C53B68A_zps
45409CC0-085C-466F-8EFD-4B1748DB1656_zps
D6EA2BEB-2222-4A0F-9EDD-57A03124BDB6_zps
4B7D885D-D255-40F7-B5E5-6B4CF9633DCD_zps
324A1E0A-449F-49A4-827A-85B765B7E4C1_zps
Overall can't see much so it looks stock (No problems with cops). The only thing that stands out is the silicone joiner and the braided oil line for the turbo. Will be invisible with a heat shield on it.
10mm spacer was needed for it to clear the block and you will need 45mm and 55mm studs if I recall correctly for the turbo to manifold connection.
Must have a metal intake for the turbo too.
  • Like 2
if anyone wants my #scotty_nm35 3" intake with 3" to 4" silicon reducer & an alloy extension piece (if you are deleting your AFM), it's up for sale soon...
Mine's a little different as it doesn't have the BOV return and the breather line it mounted slightly different to delete the factory hardlines, intake mates up to the factory airbox (if you need it).
12108237_1139761716052956_84809291911063
  • Like 1
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
