Its on my X-trail, getting tuned as i speak.
running 7psi hoping for about 260awhp.
QR25DE+T (2.5L 4cyl)
And yeh that's the manifold im using. I took those photos myself, when i was helping my mate make that manifold.
Just trying to find some more specs on it, cos all i was told is its off a Z31 300zx single turbo...
Its bin rebuilt since then, and i didnt get around to asking the guys at turbo tech if they knew.
I have a hi flowed one of those on my 33, if its the normal vg30det turbo then it will have a .6 rear housing, they had ceramic rear wheels standard but that should have been changed when it was rebuilt, if not they can handle 15psi becuase they have a thicker shaft than r33 turbo's, no idea on front wheel and housing sizes as mine uses a standard 33 comp cover that has been machined out to fit the to4 comp wheel.
what are your thoughts about one of your new wastegate actuators (the upgraded beefy ones you'll run on the .82 rears) on OP6 G3 i have?
Its a CAT machinery actuator. by spec its rated to a bout 26psi. I bench tested it, it started to open at 18psi. I got skyline with 5 broken pistons at moment. So waiting for engine overhaul at this stage.
I'm currently under going some creative modifications to stock R33 2IU turbine housing aim is to push out 270rwkws out of this and possible 290rwkws out of the OP6 rear housings. Well only if current meth works.
Thanks for the support guys, I will let you know if I need your car to do trail runs.
268rwkws @16psi out of a Powered up R33 turbo high flow.
Any one's running 300zx here?
320rwkws out of twin ATR25s on a stock VG30dett Z32 with 750cc injectors, SMIC, and flash tune.
how did you go with the "creative mod"?
The creative mod has been sold to kwrickr33 for evaluation so PM him for results.
Water fittings is M18x1.5 same as your stock fittings. PM me if you need the high pressure CAT actuator when ready for tune.
Its $180. Tested it today. It did hold it pretty fine and blewn up my engine again at 21psi. lol Not sure what the $&%^ happened. Engine's comming out again.
Well. It isn't that bad. because the actuator did hold 21psi. So this actuator can hold boost.
It seems to be the EBC's solenoid failed for some reasons. It was holding 9psi, 12 psi, then the last run was on 15psi. It was all smooth then felt just like the boost line to actuator popped off. Boost went sky rocket. and Boom. Actuator is fine.
Just quick note:
Our last day this year is Tuesday 22nd of Dec and will come back on 15th of Jan 2010. I will get all of yours orders made and sent before we finishing off.
It has been an amazing year, I like to thank you all for your support in 2009.
Merry Xmas + Happy new year to you all.
Bugger..... was it forged or stock? 21psi is getting a bit excessive on an old engine too.. you can see why i dont like anything over 19psi unless i know the car intimately.
The engine originally had 5 cracked pistons through the ring lane area. So I replaced those pistons with a set of brand new OEM pistons and rings. I got them for $500 off some one who bought them and ended up forgies. The engine noise you heard earlier was gone straight after rebuild.
My boost gauge has scale for of 20psi so I guess the tuner wasn't be able to read it if its above. So he said 21psi as the niddel stops there. It was running a ATR43G4 which is identical to a GT3582R in .82 rear.
Well its worth spending $3500 to find out the actuator that works. All for science and my customers.
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
