hey stao just wondering say if i give u a HKS2535 turbo can u like put bigger wheels on it and like make the housings flow more if so how much? and what would the response and hp be like?
Cheers
Chi
If the turbo is working I suggest to sale it and we can buil you a new one. But if its dead we can high flow that with a Garrett GT3071 chra. will have very similar sort of response, and maxes at about 260rwkws. This will cost roughly $1350 mark.
Yes it should. I fitted one to my own car and it seems to be ok. Well you are welcome to send the unit back to swap for a bolton turbine housing.
Its a pretty generous offer. I think you should take it. Plus you can connect a 3inch pipe straight into the ATR43's turbine housing, which will flow heaps better then that little 2.5 inch pipe.
Edited by kwickr33
my atr28 has a 3" inlet already. Its all fitted now apart from the dump. Just wanted to make sure the stock front pipe is ment to bolt up so i dont waste my time.
Here are some updates. I spent a day working on this and turned a blown R33 turbo to a sleeve bearing HKS2530 (Yes even machined matching compressor trim). By calculation it should produce exact amount of power and response as the actual 2530.
Its for sale complete with $1000 with oil line and high pressure actuator (1.2KG) for how ever's interested to provide some dyno sheets. From calculation this turbo is good for a super responsive 220~230rwkws on about 15psi of boost.
The cost to high flow any R33 or R34 turbos in this way cost $1050 including braided oil feeding line or $1150 with high pressure actuator.
I am intrested in buying this :-)
Here are two photos of your job. Turned a KKR480 to a sleeve bearing 3582 in .70 front with Anti surge slots and .69 rear. I'm pretty happy with way of how the angled slots we drill came out.
My Camera wasn't very good. Please upload few photos when you get it. Cheers.
What would be the cost to get this done? Will it go onto a stock manifold and still be able to use the internal gate?
Finally got everything hooked up. Had to unbolt the middle exhaust mounts to do some tweeking but all good.
Here are some pics
Hitting R&R at 12psi so its pumping out alot more air. The 28G4 is quite abit laggier but not that bad and after a tune it should be alot better.
time to get the old Nistune software out will post results when i get it all done and on the dyno
Including the .70 comp housing and the anti surge slots, it will cost $1230 to carry out. If your current internal gate works then your are still be able to run it internally gated.
for the GTR's that run 2 x 2530's are they just the exact same as what non-Rb26 owners would put on? Or were the GTR 2530's slightly different when running a dual setup?
the exhaust housings have different flanges, so its not interchangeable.
every dyno graph i see here has the same boost drop problem as our highflow that we are running on a mates car.
Comes up to 18psi at around 3800rpm, slowly dies off to 15psi as u approach redline, no matter what you do, mind u, all new gaskets, no gasket leaks! haha
the turbo was a gt3076r core, stock rb25 housings machined on, power delivery is very impressive, excellent for street, linear torque curve helps keep traction also
its just a shame the stock manifold and housings cant hold the boost till redline above 1 bar ...
what do u charge to build a turbo to this specification?
Well the boost pressure drop depends on the turbine housing pressure and the wastegate's spring load. Most of .63 and bigger turbine housings used on RB25det can be internally gated with a high pressure actuator to hold boost curve steady to certain point (18~21psi).
Most of turbos we built or high flowed are fitted with a standard actuator. With high pressure actuator below, I've tried it on my own and also few customer's R33s which did manage 21psi flat using .82 turbine housinged ATR43G3 turbo. This actuator Cost $150 additional with all high flows and brand new turbos:
To build a sleeve bearing GT3076 spec turbo in .82 turbine housing with OEM bolton pattern we charge $1450AUD including oil feeding line.
To build it with Garrett GT3076 Ball bearing CHRA using our .82 turbine housing with OEM bolton pattern is $1850AUD.
1850 isnt a bad price, can you email me any dyno sheets with this turbo fitted to an rb25? what boost levels is it capable of holding till redline ? [email protected]
for the record, the turbo was fitted with an uprated 12.5psi actuator and a profec b was being used
what is this .82 rear housing? where is it made? how much power can this rear housing expect to make on std cams ?
Edited by snozzle
    • That still isn't a lot to go on. I don't have a Y50 Fuga Head Unit wiring diagram. I can say that a lot of nissans of that age shared head unit plugs, so if you are in Australia something like this would probably help: https://aerpro.com/app091# You plug that into the car loom, then either plug the head unit ISO into that (if it has ISO), or you buy and ISO adapter harness that you wire in. Bit of stuffing around, but once you have ISO its easy to change things in future.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
