It does look like the diagram has been rehosted, albeit a new version. Still factually incorrect unfortunately.
Quite amazing how that is even possible when I've already told him HOW it was wrong to begin with.
Have a look at the 2nd diagram, then look at my first reply and I am quiote confident even someone with grade 5 maths can work it out.
Perpendicular in the real work, parallel in the picture description. Fact remains the diagram is still wrong and blatantly sladering products.
Not ALL split dumps are bad. Such a blatant and incorrect comment should never have been made.
It does ....... made.
Stao's referring to the ebay model as you can see in the photo. We all got the idea of why it doesn't work, you don't have to be a smart ass telling every one he's dawning is not up to spec, and I don't see your 10 years turbo experience solved any member's potential problems or he will not be posting this. So keep your shit to your self, no one’s interested in it, don't post any crap unless its helpful to make things better.
just my 2c
Yeh dude, seriously dont write crap that is not useful, Tao is here to help us SAU'rs in turbos. I've had Tao's turbo's for years now, ive used it on a track and has never done any damage, I will be posting up dyno graphs soon of my new tune with a new highflow, Im using a cheap chinese dump pipe where it had a divider in it, i had to take mine off to fit it in my .63 rear housing.
Cheers,
Geraus.
just my 2c
Not upto spec? Factually incorrect is what the diagram is. If highlighting incorrect information is being a "smartass" then god help us all.
It would appear you do still do not understand the key flaw in said diagram. Fair enough, but that does not mean that other more educated users won't come along and understand.
Everyone is interested about factual & correct information. Something which I have cleared up here (even if Hypergear refuse to take down incorrect diagrams).
Not useful? Highlighting factually incorrect information is very important to expand ones knowledge. Were it not done, users would have been mislead/misinformed (once again).
Now the information is there, anyone that thought it was correct advice now knows that it is not, hence why I felt the need to post where I rarely would. Some less educated users would have taken the "experts" word as gospel when sadly it is far from it.
Guys I would like to keep this thread clean with information on turbo profiles and results only.
My diagram is not up to spec, just simply drawing so people get the idea. Please do so if you would like to draw a more detailed and specific diagram.
No more arguments about the drawing. Thank you all.
Please let me know if any one's welling to evaluate the new turbine wheel. Free dyno tune at Dr.drift for people with adequate mods.
Small update. This is from a customer's skyline running ATR43G2 in our .82 bolton turbine housing with restrictive intake pipe and stock airbox which resulted in boost drop. Not the best but I think its still a good overall result in comparing power curve with some of the OP6 high flows, and the power band still rises at 7000RPM, will make lot more power with a free flow 3inch metal intake pipe and a pod filter.
Naa looks like the turbo's can't suck in any more air out of stock induction pipe and air box. This turbo should be able to make a healthy 280rwkws.
This is my car.
I've finished the intake now (3" metal pipe with bov return and breather line welded into it, to pod filter) and it made a HUGE difference. Boost comes on about 500rpms earlier and holding boost strong untill redline.
Gimma a couple of weeks and I'll have it dyno'd again, should see some nice gains! :P
Can possibly high flow it with a BDR351 Comp wheel working with GT45 turbine wheel. Should pump out 1200HP. What sort of housing is it in?
Stao - Can you do anything with Toyota CT-12a's (1JZ twin turbo)
edit - just read through your website, how much to do 2x CT12's and what is done to them?
Andrew you have not even picked up the car yet and you doing the turbos. I LIKE YOUR STYLE!!!!!!!!!!!! :P
Have to modify toyota housings to suit Garrett bearing housing first, then profile them to suit larger wheels. They can be high flowed to some thing close to a 2060rs disco. you will need new water and oil lines once done.
Very similar to this:
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
