i'm guessing tin can or pipe the size of the intake pipe (to the turbo) with an air hose fitting and a bottle of soapy water (old school bicycle inner tube leak style) and go over all the joints
Have to ask Trent, he did some process to tune it. Dont know much more about it.
I just know the car feels a lot laggier and less power. Dont even really need a dyno but the dyno backs it up how it feels.
we were comparing different cars so the folder thats opened last will be shown.
Ahh k..yeah it was unlikely it would cause a 20kw difference anyway, just found it odd..
Could it be your WG isnt closing properly??
Stao, just a quick one I think would be valuable to your thread;
Are you able to back cut exhaust wheels?
I want to do this to make 2835 from 3071 or 3240 from 3540, thanks.
To trim or back cut wheels. yes we can do that. you need to give me the specs thou. or a set of 2835 housings.
Yup exactly, I bought some pvc caps from bunnings and use a silicone joiner and clamp to block off both the intake and the throttlebody. Then put an air hose fitting into the intake cap and insert air pressure. Any leaks I have had on previous cars have been quite loud and very easy to locate.
Just need to find my damn pump!
Interesting plot of the same turbo on Tao's car (yellow and green) and my car (red):
This is with the car running as it was previously making 279rwkw. Both yellow and red are running just off the actuator (no boost controller) but on Tao's car he is able to hold the boost flatter and get more boost up top.
Did you reinstall the bov afterwards? I cant see how a bov restrictor plate could reduce power? Affect driveability sure.
No i threw that plate in the bin it had cost me alot of money trying to find the problem! well it was messing around with the cars afrs, and at 10% throttle it would open the bov and hiss, could only hear it on the dyno and then the car would dump in petrol making it run really rich. I was there when my tuner did it, i couldnt believe it too but taking it out worked, u could hear the car was running so much better!
could it be possibly different parts such as exhaust, dump pipe, cat, air intake, intercooler brand, piping and design? better sealing of cylinders as tao has just rebuilt to stock spec with cp forgies. Maybe try another actuator? maybe a leak in a small pipe such as the ones going to the stock boost controller?
hopefully its just a leak somewhere which is nice an easy to fix :)
Edited by DJSimmo
Just to clear it up that red plot was when the car was running right. I am happy with my dyno being 5rwkw of so less for most of the curve and a bit less at the top cause the boost isnt holding. When you look at the peak power figure mine is quite a bit behind Tao's but if you look at the curve its only right up top that there is much of a difference.
I just want to get back to the red curve. Yup I am hoping its a leak somewhere too! I am not running any boost controller, not even the standard one. I am using the same actuator as what Tao used in those green and yellow plots. I will look into getting boost to hold flat later on, at the moment I am just focussed on finding this issue.
Ok, so got home last night and pulled out my boost leak tester. Found a big leak on the joiner on the outlet of the intercooler! It was quite late so I didnt get a chance to try and fix it. But I am very happy to have found it! Cant wait to get home to fix it.
nice... and you didnt need to pull the front bar :P
Don't assume that's the only leak though, still go over everything else to be sure. Otherwise, congrats! Hope it goes better now :P
Once I have replaced that hose and clamps I will retest for leaks until I am happy.
hahaha yup I was dreading taking off the front bar and driving across melbourne. I get enough cop attention already, without a front bar would be suicide!
LOL at that leak tester! Good work
Hahaha I know it looks ghetto, but it works really well. Because there is no other noise its really easy to hear the leak.
Exactly, may be a bit ghetto but cheap and gets the job done! Thumbs up :P
    • Man, I'm kind of amazed that the price of the turbo has not changed in 7 years. Everything else is inflating beyond reason, but not this? Good on Tao / hypergear I guess? Anyways, good luck with the sale!
    • I'm selling my brand new, in the box, never used Hypergear ATR45 - and I had some additions I paid for a few yrs back when I purchased it. Never ended up having the rest of the money to add all the mods at once, so I just ended up slowly selling each part. I originally had it internally gated, with the dump pipe, however I found it was incompatible with what I was going to use it for, so I contacted (I think Ken) from Hypergear, and he and I messaged back and forth & he got me to ship the turbo back, where they modified it & made it externally gated, and gave me the 5 bolt dump pipe attachment for custom welding. (Photos below) This turbo like I said has never touched the inside of an engine bay, it's completely brand new, never used, been sitting in the same box it arrived in, covered in plastic & all. Below are the photos of it: And while the guys at Hypergear were making it in-shop, they sent me some photos of the process: I'm looking at selling this just because I'm in need of the money right now, and don't have plans on modifying the 34 anytime soon - and from reviews & peformance sheets, this turbo had amazing results back when I was researching. The turbo was purchased in 2018 for $1.9k, with the mods I got added on. Looking at the website now, for the same turbo they sell (ATR45SAT), with the current addons it adds up to $1830 for the turbo Current addons included: - Bolted dump adaptor - Ball bearing CHRA - Braided oil feeding line So I'm looking to possibly sell it for around $1800, with shipping included in that 1.8k, It cost me around $120 to ship - so yeah thought I'd throw it out there and see if anyone was interested in purchasing. Cheers!
    • Turn up your speakers https://youtu.be/5_GK5ChNjOs?feature=shared
    • This thing did a 1:20.88 at Winton on the weekend which is f**king rapid.  Well done mate, your driving has really gone up a few notches not much left on the table now! Good luck at WTAC.   https://www.facebook.com/share/r/1MHyZQBqZ2/
