Why bump lol?
I took my cat out today to have a look, but it doesn't look melted from what I can see. I am however still doubting how well it flows, as the entrance to the cat was very very dirty and black while the exit was almost as clean as when I put it in there. Not sure if that is normal for a high flow. I also tried shining a torch down one end and looking down the other, and hardly any light makes it through. You can only just see the light coming through to the other side. Normal?
For the lash setup there isn't much of choice, I only found Tomei Type A, B and Supertech. It appears the supertech ones are 15LBs stronger then the Tomei Type B spring kit. I will be using those.
http://cgi.ebay.com.au/Supertech-Valve-Spr...=item3a52093c3b
Hanalado: The cat won't appears as melted like butter. a good performance cat has very big cells. Ie. 120 cells in a 4inch barrel. Also been a .63 rear housing the amount of lag you've got is greater then people using a .82 rear housing. I would suspect leaks on the intake side which including unsecured spark plugs, BOV, head, plus all clamps and hoses.
Hrmmm Im about to change the cams and clean the lifters and go for a retune now Im wondering how worthwhile it would be to change the springs while I got it all out.
Why bump lol?
We had a s13 silvia lose 40kw by fittin a cheap highflow cat. Putting the decat pipe straight back in giving it a run without changing anything went from 205 to to 245kw
Emphatically, YES.
Regardless of whether you're paying for someone else's time, or using your own time, dropping in new valve springs while cams are out is a no-brainer. Just got to be sure the method used will ensure the valves don't drop down into the chamber.
I hate having to go back over my own work to make an improvement I could/should have made the first time around.
Why bump lol?
what brand and type of cat?
thanks stao!! keep us updated!!
Cheapo brand, Venom or something. Advertised as a 100 cell high flow, 3" inlet/outlet with 5" body. I never really expected it to be that good, but I didn't have the money to pay $400+ for a cat.
I was going to gut the cat, but don't want to change anything until my tuner has his dyno back and can check the tune, make sure it's not leaning out. I'm also not really keen on running a decat, so will probably save for one of the expensive brand name cats.
i'd consider a new one
just don't buy an xforce one, pretty much the only car guaranteed not to pass emissions tests
something like this will be fine http://www.justjap.com/store/product.php?p...=275&page=1
regarding the x-force one, they say it meets Euro 3 emissions standards or something...I take it that's not enough for Aus?
Also, I wouldn't particularly recommend using that Just Jap one either - since it doesn't specify, I'd assume it's ceramic? That'd be a stupid move to put another ceramic cat back in.
Yup stuff the ceramic. I bit the bullet and bought this metal cat:
http://www.justjap.com/store/product.php?p...cat=&page=1
It has served me well and dynos between cat and no cat were within 5-10kw.
Yeh that's a race cat though, just as illegal as a decat.
What's the deal with ceramic cats? I know they are shit when it comes to modified cars, but why can they not handle the heat? I thought ceramic was meant to be one of the best materials for dealing with heat?
I think the amount of stock ceramic turbo wheels vs the amount of steel turbo wheels that end up in the cat is good evidence that it is not.
Why this is I do not know, you are correct ceramic is meant to be tougher and withstand higher temperatures, perhaps it degrades faster over time and steel does not? Maybe it is more brittle and cracks easier.
edit: apparently ceramic is cheaper and hence tends to be used in much cheaper manufacturing processes with more flaws which is why they are generally worse, if they were made to the same standard as the expensive steel ones they would perform better, at least that's what the reading I just did told me.
Are all the melted ones we see stock cats? or are we seeing aftermarket ceramic ones melt as well?
Edited by Rolls
Incorrect:
http://www.catco.com.au/mainFrameset.htm
CATCO METALcats are ADR approved AND meet EPA requirements
Sorry mate, incorrect. There are 2 issues with ceramic turbos.
Number 1 is, the shaft is not ceramic, the wheel only is ceramic which in most cases is fixed to the shaft by an epoxy. When EGT gets too high the epoxy melts and the wheel becomes dislodged. This is why the turbo is generally left with no trace of the wheel beyond the shaft.
Number 2 is the ceramic wheel expands and makes contact with the housing more so than a steel wheel. This sees the wheel shatter in an instant.
Number 2 was shown when the $250 high flow thread was around, porting the rear housing to drop surge proved to also drop EGT which made the turbo last a lot longer (with the standard ceramic rear wheel and at 17psi).
Also you are correct in saying that metal cats melt, not ceramics. Ceramics collapse.
I should have taken photos of the guts from mine when I bashed it out....well, I might still be able to find them on the ground so I may very well back this up. Mine most certainly was melted. Maybe not from heat as such, could have been acidic melt if any of the unburnt fuel could possibly do this....but it was definitely melted. And as far as I know it was aftermarket as the heat shielding was branded CATCO
Thanks for the post, I did not know it was the expoxy that failed in the turbos along with expansion, cheers for clearing that up.
Re the cats melting, all I was getting at is they fail, I am still unsure why though as ceramic is meant to be harder, stronger and able to withstand higher temps.
Perhaps it is the expansion in the ceramic cats that causes them to fracture and collapse.
Edited by Rolls
Obviously it is possible for the thing to melt, yet not common.
Keep in mind the exterior of a space shuttle is also ceramic. If your cat was subject to some atmospheric re-entry temperature, you present quite the challenge!
lol there are different types of ceramics :P
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
    • meh, it was a good video, clear about the issue and how he dealt with it. A bit heavy on the RTV and very brave to put an RB in anything without rebuilding it first, but otherwise I thought it was good Dose, I'm not sure that having the pickup forward is a big issue; yes of course the oil could shift under brakes but the sump should never be empty enough for that to be a problem (unless you also have a higher volume oil pump, and that oil can't return from the head to the sump quickly enough)
    • I can donate $100 to your upgrade fund. So long as you can donate the IC7 my way....
    • I'd love a Haltech ECU, and Haltech 10 dash. Was having a chat with Rob and Andy @ Haltech when Rob put one in his MR2. First one I'm kind of interested in too, as you can dim it RIGHT down. Andy was saying bright dashes is one of his peeves too!
