Why bump lol?
I took my cat out today to have a look, but it doesn't look melted from what I can see. I am however still doubting how well it flows, as the entrance to the cat was very very dirty and black while the exit was almost as clean as when I put it in there. Not sure if that is normal for a high flow. I also tried shining a torch down one end and looking down the other, and hardly any light makes it through. You can only just see the light coming through to the other side. Normal?
For the lash setup there isn't much of choice, I only found Tomei Type A, B and Supertech. It appears the supertech ones are 15LBs stronger then the Tomei Type B spring kit. I will be using those.
http://cgi.ebay.com.au/Supertech-Valve-Spr...=item3a52093c3b
Hanalado: The cat won't appears as melted like butter. a good performance cat has very big cells. Ie. 120 cells in a 4inch barrel. Also been a .63 rear housing the amount of lag you've got is greater then people using a .82 rear housing. I would suspect leaks on the intake side which including unsecured spark plugs, BOV, head, plus all clamps and hoses.
Hrmmm Im about to change the cams and clean the lifters and go for a retune now Im wondering how worthwhile it would be to change the springs while I got it all out.
Why bump lol?
We had a s13 silvia lose 40kw by fittin a cheap highflow cat. Putting the decat pipe straight back in giving it a run without changing anything went from 205 to to 245kw
Emphatically, YES.
Regardless of whether you're paying for someone else's time, or using your own time, dropping in new valve springs while cams are out is a no-brainer. Just got to be sure the method used will ensure the valves don't drop down into the chamber.
I hate having to go back over my own work to make an improvement I could/should have made the first time around.
Why bump lol?
what brand and type of cat?
thanks stao!! keep us updated!!
Cheapo brand, Venom or something. Advertised as a 100 cell high flow, 3" inlet/outlet with 5" body. I never really expected it to be that good, but I didn't have the money to pay $400+ for a cat.
I was going to gut the cat, but don't want to change anything until my tuner has his dyno back and can check the tune, make sure it's not leaning out. I'm also not really keen on running a decat, so will probably save for one of the expensive brand name cats.
i'd consider a new one
just don't buy an xforce one, pretty much the only car guaranteed not to pass emissions tests
something like this will be fine http://www.justjap.com/store/product.php?p...=275&page=1
regarding the x-force one, they say it meets Euro 3 emissions standards or something...I take it that's not enough for Aus?
Also, I wouldn't particularly recommend using that Just Jap one either - since it doesn't specify, I'd assume it's ceramic? That'd be a stupid move to put another ceramic cat back in.
Yup stuff the ceramic. I bit the bullet and bought this metal cat:
http://www.justjap.com/store/product.php?p...cat=&page=1
It has served me well and dynos between cat and no cat were within 5-10kw.
Yeh that's a race cat though, just as illegal as a decat.
What's the deal with ceramic cats? I know they are shit when it comes to modified cars, but why can they not handle the heat? I thought ceramic was meant to be one of the best materials for dealing with heat?
I think the amount of stock ceramic turbo wheels vs the amount of steel turbo wheels that end up in the cat is good evidence that it is not.
Why this is I do not know, you are correct ceramic is meant to be tougher and withstand higher temperatures, perhaps it degrades faster over time and steel does not? Maybe it is more brittle and cracks easier.
edit: apparently ceramic is cheaper and hence tends to be used in much cheaper manufacturing processes with more flaws which is why they are generally worse, if they were made to the same standard as the expensive steel ones they would perform better, at least that's what the reading I just did told me.
Are all the melted ones we see stock cats? or are we seeing aftermarket ceramic ones melt as well?
Edited by Rolls
Incorrect:
http://www.catco.com.au/mainFrameset.htm
CATCO METALcats are ADR approved AND meet EPA requirements
Sorry mate, incorrect. There are 2 issues with ceramic turbos.
Number 1 is, the shaft is not ceramic, the wheel only is ceramic which in most cases is fixed to the shaft by an epoxy. When EGT gets too high the epoxy melts and the wheel becomes dislodged. This is why the turbo is generally left with no trace of the wheel beyond the shaft.
Number 2 is the ceramic wheel expands and makes contact with the housing more so than a steel wheel. This sees the wheel shatter in an instant.
Number 2 was shown when the $250 high flow thread was around, porting the rear housing to drop surge proved to also drop EGT which made the turbo last a lot longer (with the standard ceramic rear wheel and at 17psi).
Also you are correct in saying that metal cats melt, not ceramics. Ceramics collapse.
I should have taken photos of the guts from mine when I bashed it out....well, I might still be able to find them on the ground so I may very well back this up. Mine most certainly was melted. Maybe not from heat as such, could have been acidic melt if any of the unburnt fuel could possibly do this....but it was definitely melted. And as far as I know it was aftermarket as the heat shielding was branded CATCO
Thanks for the post, I did not know it was the expoxy that failed in the turbos along with expansion, cheers for clearing that up.
Re the cats melting, all I was getting at is they fail, I am still unsure why though as ceramic is meant to be harder, stronger and able to withstand higher temps.
Perhaps it is the expansion in the ceramic cats that causes them to fracture and collapse.
Edited by Rolls
Obviously it is possible for the thing to melt, yet not common.
Keep in mind the exterior of a space shuttle is also ceramic. If your cat was subject to some atmospheric re-entry temperature, you present quite the challenge!
lol there are different types of ceramics :P
    • Yeah i found that alot of parts can be wrong or "very" hard to get the real right one. I already bought some brakes years ago on me "old" GT calipers and they were wrong too 😄  I told them too. Even send them pictures...but they said "EBC catalogue has them on my car... So i dont know what their answer will be. I call monday them and let them know that they are really not on my car. If they were they would be already on a car...
    • Welcome to Skyline ownership. Yes, it is entirely possible parts websites get things wrong. There's a whole world of inaccuracies out there when it comes to R34 stuff (and probably 33 and 32). Lots of things that are 'just bolt on, entirely interchangable' aren't. Even between S1 and S2 R34's. Yes they have a GTT item supposedly being 296mm. This is incorrect. I would call whoever you got them from and return them and let them know the GTT actually uses 310mm rotors. Depending on where you got them from your experience and success will obviously vary.
    • Hi...a bit a "development" on the brakes. I spoke to the guys where i get brakes from...and they are saying that 296mm EBC are for R34 GT-T. I then went to their site: https://www.ebcbrakes.com/vehicle/uk-row/NISSAN/Skyline (R34)/ and search for my car(R34 GT 1998 - it has GTT brakes) and it show me this USR1229 number and they are rly 296mm rotors... So now iam rly confused... The rotors i have now on the car are 310mm asi shown... So where is the problem? Does the whole EBC got it wrong or my calipers are just...idk know what?
    • Oh What the hell, I used to get a "are you sure you want to reply, this thread is XX months old" message. Maybe a software update remove that. My bad.
    • This is a recipe for disaster* Note: Disaster is relative. The thing that often gets lost in threads like this is what is considered acceptable poke and compromise between what one person considers 'good' looks and what someone else does. The quoted specs would sit absurdly outside the guards with the spacers mentioned and need  REALLY thin tyres and a LOT of camber AND rolling the guards to fit. Some people love this. Some people consider this a ruined car. One thing is for certain though, rolling the guards is pretty much mandatory for any 'good' fitment (of either variety). It is often the difference between any fitment remotely close to the guards. "Not to mention the rears were like a mm from hitting the coilovers." I have a question though - This spec is VERY close to what I was planning to buy relative to the inboard suspension - I have an offset measuring tool on the way to confirm it. When you say "like a mm" do you mean literally 1mm? Or 2mm? Cause that's enough clearance for me in the rear :p I actually found the more limiting factor ISNT the coilover but the actual suspension arms. Did you take a look at how close those were?
