You may as well finish off the steps that have been suggested.
Then you will need to find another e-clip before you should boost it. You can still drive it as the rod will stay there, just dont boost it as it may fall off and if you nail it will go infinity boost. The e-clip should just slide out sidewards.
Yeh I've completed the steps, it appears the actuator was already perfectly adjusted as I didn't have to adjust it at all according to how Stao said to do it, so I can rule that out as a possible cause of my trouble. In the process of getting the rod back onto the arm now but fark me it's hard lol. Where can I get another e-clip from???
Edited by Hanaldo
Ok sweet, thanks mate. I suppose for size I can just take the broken eclip along?
I can not get this farkin rod back on the wastegate lol. Kind of emasculating, I can't even get it to budge :blush:
repco, sprint auto parts, autobarn, etc. the clip should be like $0.50c
dont worry, lost mine recently as well.
to put it back on, it'll be hard as fark, use a pair of pliers to pull like buggery, slip it on a bit, and hammer it down into place
take a off-boost drive down to your local auto store and grab a new clip. install with pliers.
all the best.
cant put my finger on what is wrong in your application. no suggestions other than retune the nistune ecu elsewhere (different dyno/operator)
bad luck about the costs Hanaldo. Not a nice feeling Im sure, trying to keep to a budget and then finding you've gone over budget with no result to speak of
All good, got it back on. Arms are scratched to shit now lol. Will have to wait until tomorrow to get a new clip, everything is shut now.
Anyway, can cross wastegate not closing properly off the list.
Here's today's tune from ATR43G2 in .63 rear housing.
Dark blue is no boost controller straight off the actuator, Max of 255rwkws @ 17psi
Light blue is with Wastegate controller, 267rwkws @ 19psi.
Driving ability is pretty good, and very agressive. Its a good little turbo for around 250rwkws mark.
Dyno run is based on 9 sec ramp timing.
I've got a strange dip around 3500RPMs not sure if its VCT related, but doesn't seems to be felt on road.
Almost identical Compare to same turbo based on an earlier run on a R34:
Also we did multiple runs today, didn't have any issues with it pinning with high boost.
If it does pin at 16psi It generally means if the turbo's having issues sucking in or dispatching air (into engine and into exhaust). Lot of shaft speed losts when this happens, and exhaust blade will act as blockage for the engine to pin.
Hanaldo I enlarged your sheet it appeared to run on 14psi??
What would cause that? Restriction I imagine? Where else could there be a restriction? Everything seems to be pointing to a restriction of some kind. I pulled all my intake and cooler piping off today, made sure none of it was blocked. Did another pressure drop test across the intercooler, only about 1psi difference. Did all hose clamps back up tightly and made sure everything was sealed, no vacuum leaks.
Stao which graph is that? I don't have a print out of boost?
I'm not sure. From what I've seen this issue happened to people whom made crappy metal filled intake pipes (also blamed the turbo). Very similar to yours scenario, which runs on very low timing, can't control boost, and any thing done to fix it made the engine pining worse. Check page 57.
Yours looks alike but doesn’t mean its the definit same problem.
My R33 S2 w. standard turbo makes [email protected] at the clutch, but that is as far as it goes :)
16PSI at 3000 rpm .... :)
Nistune, Cams, De-Cat, etc ...
a stock turbo'd rb25 making "way over 200rwkw" on 14psi... stao, whatever you are on can you pls organise me a pound? ;)
also trent's dyno with the appropriate correction reads the same as a dyno dynamics, my car has backed this up on 3-4 dyno's now
yea, which would amount to all of 190-200kw at the treads champ.
We talk rear wheel kw here, as measured off the rollers or hubs.
240kw is going to net you around 200-220rwkw.
You sure it is the stocker turbo? You realise the exhaust wheel is made of glass, well ok ceramic. Anything after 12PSI is asking to have the exhaust wheel end up down the exhaust.
Tao it would be interesting to see the ATR43G2 in .63 with some boost control. Comparing it to the 3071R's in the results thread it is laking in response a little, even against the .82 rear. And
youre run has is starting off at 1.4bar and bleeding off, where as the 3071's run a pretty constant 1.1-2bar'ish
I have the exact figure somewhere .. but I sure did not lose 50KW on the way to the wheels :)
But as said, this is as good as it gets with the standard turbo, and I never stress the turbine for too long ..
Hi!
Yes, it is the standard turbine ..
I ran this type of boost for over 14 months now ...
But as said, the turbo is not overly stressed since I rarely use the full boost for long.
Also I only have a SMIC from the R34 ..
I heard many stories about how much this unit can take, eventually the turbo might die :(
So I am already doing the research for a new turbo if my old unit should fail me one day ..
I definitely want to keep the low lag of the standard unit, so 14.7 PSI at 3000rpm is a must.
Attached is an older dyno-run.
Ignore Torque figure / shape, since the operator did not tie my car down well enough
Edited by Torques
Tao it would be interesting to see the ATR43G2 in .63 with some boost control. Comparing it to the 3071R's in the results thread it is laking in response a little, even against the .82 rear. youre run has is starting off at 1.4bar and bleeding off, where as the 3071's run a pretty constant 1.1-2bar'ish
The one you've seen (based on status reading) are on 12 sec ramp timing, I've already tried to compare those at status,. mine's on 9 sec with current software. Based on 9 sec ramp they almost the same. information and comparision on dyno ramp is in page 73.
That is a very standard G2. The ATR43SS series with FNT turbine is probably some thing to look at if you really want the power curve to stand out.
I've running a high pressure actautor so won't be able to run any thing less then 20psi. The R34 Neo motor was running on 15psi and made the same power every where as mine which is interesting.
Hanaldo, Ive said this a few times on the forum yet a few years back I experienced a problem similar to yours.
The issue was I had an 80mm front pipe and a 76mm cat. The 4mm smaller ID caused all sorts of issues and resulted in about 60rwkw less than expected. We swapped to a fairly standard 80mm cat and got the 60rwkw back.
Im not suggesting your cat is bad or the wrong size, but im suspicious about your custom made dump. For the money I highly recommend you grab a justjap bellmouth dump, they are only $189 brand new... Im not sure how much shipping to WA will be though.
    • Hi guys, long time no post as per usual! It's been a busy year so far, the biggest thing being a new job.  After 28 years in the automotive industry I decided it was time for a change.  I was losing faith in the industry and where it's heading.  Now in a completely different industry (electrical) working for a company that manufacture water pump contollers.  Not as sexy as cars but it's an interesting,  challenging industry. I now don't work Saturdays which is a bonus!  It's still 50-55 hours a week but having Saturdays ack after 28 years of working them is awesome!   No news on the GT-R but i did decide to add some more JDM goodness into my life....           1990 300 ZX.  She's not perfect but for a 35 year old car she ain't bad!  Just going to tidy it up a bit and enjoy it.  It's currently auto but will start stockpiling everything for a manual swap. It WILL distract me even further from the GT-R but im hoping not for too long! It somewhat proves a 6'8" freak can fit in a 300 ZX.  Sort of...  I drove it home from the previous owners house in Melbourne via Black Spur and Merton Gap (2 awesome bits of Victorian twisty road) and it was amazing!  Handles so well!!!   I don't think it would be worthy of a full build page but I'll post up some of the upgrades here if anyone is interested?  Cheers guys!
    • End game is to: - Remove all the slop from old worn parts - Adjust setup so that the wheels actually fit and the car is drivable (currently it is not because of the extreme rubbing on the guards).   Progress over the last couple of days, removed the rear hubs! Next steps: - Buy bushings - Replace bushings/bearings on hub - Reinstall
    • Cracked deck  And other cam snap stuff
    • A few random issues have popped up since my last update. My WMI pressure sensor failed within about 10 minutes of it seeing liquid. It was a 20$ China special, so I'm not surprised. My name brand replacement should arrive today.  My power steering assist also decided to crap out last weekend. The usual, works for about 60 seconds after starting the car then I lose it. I dusted off my old copy of NDS and connected to the HICAS ECU. Code 4 for assist solenoid.... I tested the solenoid and it's fine.  I knew the day where my HICAS ecu would crap out would come, and I welcome it. It was the last HICAS part on the car that is now in the bin. I've ordered an SSR and I will control the power steering solenoid with my Haltech ecu. It will be nice to have proper speed referenced assist again after all these years.
