If it truly has full boost at 3k I really doubt it'll make over 250kw
garret who have far more engineering experience can't even make a turbo that does that, sorry to be negative but I just can't see it being true.
See turbochargers engineered in this project are solely for RB25det engines, Garrett would make a turbo to suit a variety of engines. There are room for improvement when designs becomes specialized.
At moment it feels like some where around the 280rwkws mark with very steady torque. Its drives very differently to any other turbos I've engineered or experienced so far. I'm expecting an out standing result.
If this turbo makes 280kw with full boost at 3k I will buy one in the near future, providing it holds the power to at least 6k on less than or equal to 20psi.
This will be a garret killer if it makes those results!
my current highflow makes full boost at ~3k but only makes 240kw on 18psi, so if I can get 40kw over that with the same response, holy shit!
What are the main engineering differences with this turbo over previous designs ?
Edited by Rolls
Always watching Stao's progress, keep up the good work mate.
full boost at 3k and 280rwkw+ may be possible as thats exactly what I have now... just with a Garrett stamp and a slightly higher price tag.
Dyno sheet please
NA + turbo does not count.
Nope - nothing special, no E85.
tuner said not much difference between what he has seen with normal turbo motor and the slightly higher compression NA with my turbo.
post-36975-0-79536600-1311255089_thumb.jpg this was with an electronic boost controller
post-36975-0-72596700-1311255208_thumb.jpg this was with a bleed valve
Decent power for the street, very useable... as soon as I touch the accelerator I get boost..
What turbo?
edit: just saw your post, how on earth do you get a GT3076 on boost by 3k? Most people are seeing 3.5 to 4k ? Was that with some ridiculous ramp rate?
Edited by Rolls
What turbo?
The two runs are not equal... There must be some decent load and hold time on the EBC run as it starts at 9psi at about 2500rpm. A normal dyno run should start at around atmospheric pressure.
Second graph looks much more genuine with 18psi at 3500rpm which is pretty much what is expected from a GT3076R with a 0.63 :)
Edited by SimonR32
Its a good result :thumbsup: , high comp engine with adjustable cam gears would make a turbo spool earlier. Plus different dynos with different sittings would read differently. Compare to one of my earlier runs using the same dyno:
RB25DE high comp, adj cam gear, 3076 .63 ext gate, with a bleed valve
Standard RB25DET motor, stock head, ATR43G3 int gate, with Bleed valve. My run ended early due to misfire while still making 294rwkws.
They looks similar in terms of Power VS Response VS KM/H. But I know the SS-1 PU is more responsive. :yes:
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
