If it truly has full boost at 3k I really doubt it'll make over 250kw
garret who have far more engineering experience can't even make a turbo that does that, sorry to be negative but I just can't see it being true.
See turbochargers engineered in this project are solely for RB25det engines, Garrett would make a turbo to suit a variety of engines. There are room for improvement when designs becomes specialized.
At moment it feels like some where around the 280rwkws mark with very steady torque. Its drives very differently to any other turbos I've engineered or experienced so far. I'm expecting an out standing result.
If this turbo makes 280kw with full boost at 3k I will buy one in the near future, providing it holds the power to at least 6k on less than or equal to 20psi.
This will be a garret killer if it makes those results!
my current highflow makes full boost at ~3k but only makes 240kw on 18psi, so if I can get 40kw over that with the same response, holy shit!
What are the main engineering differences with this turbo over previous designs ?
Edited by Rolls
Always watching Stao's progress, keep up the good work mate.
full boost at 3k and 280rwkw+ may be possible as thats exactly what I have now... just with a Garrett stamp and a slightly higher price tag.
Dyno sheet please
NA + turbo does not count.
Nope - nothing special, no E85.
tuner said not much difference between what he has seen with normal turbo motor and the slightly higher compression NA with my turbo.
post-36975-0-79536600-1311255089_thumb.jpg this was with an electronic boost controller
post-36975-0-72596700-1311255208_thumb.jpg this was with a bleed valve
Decent power for the street, very useable... as soon as I touch the accelerator I get boost..
What turbo?
edit: just saw your post, how on earth do you get a GT3076 on boost by 3k? Most people are seeing 3.5 to 4k ? Was that with some ridiculous ramp rate?
Edited by Rolls
What turbo?
The two runs are not equal... There must be some decent load and hold time on the EBC run as it starts at 9psi at about 2500rpm. A normal dyno run should start at around atmospheric pressure.
Second graph looks much more genuine with 18psi at 3500rpm which is pretty much what is expected from a GT3076R with a 0.63 :)
Edited by SimonR32
Its a good result :thumbsup: , high comp engine with adjustable cam gears would make a turbo spool earlier. Plus different dynos with different sittings would read differently. Compare to one of my earlier runs using the same dyno:
RB25DE high comp, adj cam gear, 3076 .63 ext gate, with a bleed valve
Standard RB25DET motor, stock head, ATR43G3 int gate, with Bleed valve. My run ended early due to misfire while still making 294rwkws.
They looks similar in terms of Power VS Response VS KM/H. But I know the SS-1 PU is more responsive. :yes:
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
