It was a joke :) He is a good mate and knows me well enough to know that if we popped the motor from silly boost I wouldn't blame him. I don't think he would be like that with his normal customers :pirate:
If it is tuned safely and correctly what chances are there of you popping a stock 25 making 260-70kw anyway? Keep it rich and nice and cool, safe on timing so it doesn't ever det, surely the pistons aren't going to melt if you keep the AFRs down?
What are peoples thoughts on making this power on the street? I realise on the track where you are WOT for 75% of the time it could be an issue due to excessive temps, but on the street?
The G2 is only a small turbo. Also Its more of the factory exhaust manifold restricting flow so the power figure is well kept around / under 300rwkws mark. Probably not worth investing a turbo that pushes beyond that unless its going to on a high mount ext gated setup, and I'm pretty sure all the current ATR43G3s has no issues making 340rwkws+ on it.
I'm considering of going for a high mount manifold with ext gate once there are nothing left to improve using factory setup. How ever that will not reflect the power figure of those without the same setup.
Once you finish developement on your stock lowmount stuff you should definitely look into a turbo suitable to an off the shelf 6boost manifold and use a Tial MVR gate.
This is the staple setup for those T67 setups, if you want to get into non stock position that is the item to beat. You will need to work hard because the price is insane :nyaanyaa:
Its actually cheaper making the T67 alike setup as there is not need spending timing in making all those bolton adaptors as well as internal gate setup. Like we only charge $1000 for the internal gated ATR43G3 units.
6boost do a low mount setup, i tuned one with a t67 and came up great... 340 @ 19psi
I know man but if your going to optimise the G3 for a high mount you no longer need all that bolt on crap. Either a simple generic 5 bolt rear or a v band external gate, should bring production cost down.
Fitting the pu 1.5 in the morning. Just going to be road tuned till the injectors arrive. Let ya'll know how it goes :D
Looking forward to it and really curious to see you opinion on this turbo in terms of driveability and power compared to other turbos you've tested :)
Thats one busy looking exhaust side, how do they compair flow wise to the high mount?
identical, high mount is only to package things easy, turbo placement has no bearing on results.
By the way this turbo on the test car is for sale with a discount. PM me if you are interested.
This is a hill climb competition footage sent in from one of our customer's S14 using ATR28G3 (268rwkws from memory) in Switzerland. enjoy
:nyaanyaa: No its not a S14 SR20det. Still a G3 turbo, but on another mighty CA18det 180sx with 310rwkws. He's on NS now.
Ok pu 1.5 has been installed. Not going to go into detail about the install just yet but a few things had to be modified.
Havent touched the tune yet as customer had to head to sydney. Went for a quick road test not exceeding half throttle and so far very impressed with the near stock response.
This turbo has a very unique and nice sounding spool up.
Will be doing a quic road tune today just to set AFR's then hopefully get on dyno next saturday or possibly during the week.
Im excited for the results
Little update:
This is a from a scrapped blown Ford XR6 turbo that we've rebuilt from scratch with a ATR45 core. Its fitted back on to a Auto XR6 (edit: NA+T) 4L with 3500 convert. Car made 295.5rwkws on 11psi with Caltex E65.
Looking back from where we first started, my dynosheet pile is about the same height as a Nissan skyline engine manual :w00t: and it will keep on getting thicker.
Any way, ATR43G3 is back on the drawing board for the 4th time, I'm hopping of gain better response while not losing the consistency, top end power or peek torque.
Tao that XR6 was a NA+t AU ford with std high comp engine.
Really? AU's didn't come with turbo's so was the turbo from another XR6 car? Or was the car a BA XR6 turbo?
Why would you do it?? Maybe not the same kettle of fish, but my standard NA EL Fairmont feels like its almost got too much power for its chassis :yucky:
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
    • 310mm rotors will be avilable from Australia, Japan, and probably a few other places. Nothing for the front can be put on the back.
    • The filter only filters down to a specific size. Add to that, the filter is AFTER the pump. So it means everything starts breaking your pump even if its being filtered out.
    • Just like in being 14mm too small (296mm) makes it not fit, being 14mm too big (324mm) it also won't fit. You want to find the correct rotor.
    • @GTSBoy Ok so that was the shops problem...they showed R33 rotors on R34 page and i did not know 296 do not fit(and are for R33) Yes i bought "kit" with rotors and pads. Pads are ok(i have GTT calipers front and rear). They have some 324mm but no 310mm. So i dont know if they would fit. I have 17inch LMGT4s So another question. Can i fit those in the rear or they are just "too" big for that?
