Yes, I'm currently making about 260rwkw. Thing is with sending off my turbo for Stao to modify, I live in Perth... So that's a huge down time for my daily confused.gif
I've got the G2, .64 housing. It's still just as quick, it still scares the pants off any mates that get in my car. It's just that I'm used to it now, 350rwhp got old quicker than I expected :(
No E85 in Perth, not at the pump anyway. I know forging won't give more power haha, I meant that when I can afford it I might forge and go for 500+.
Get a bigger rear, or get water meth injection and give it more boost and more timing!
If you are bored with the power take the car off the road for 2 months, it will be even faster than than when you first put the turbo on.
My car was off the road for 5 months, when I got it going again f**k me dead it was amazing, the handling was the first thing I really noticed but the power was scary after driving a 1.3L barina for all that time.
So the SS1PU makes 260-280kw depending on boost on the status dyno but I cant find any results on any other dynos or from actual customer cars.
I have ordered an SS1PU and im a little worried that it will not perform as reported. The only result I see in Sydney is from Sarge and thats for an SS2 with some setup related complications.
Can anyone share their SS1PU results on a dyno other than from status?
Dont have a dyno printout yet but 232rwkw on 14-15psi before coils started to breakdown.
(this will give you some idea of potential of the PU)
when new coils & plugs inserted will get retune to fix boost up to 19-20psi and will post up dyno
Regards,
Dazza
Edited by itshimdazza
Before going for the next tune, Please drive pass and swap for a 20psi actuator once you have the coil packs fixed.
I'm waiting for Stao to finish up on my SSv2, hopefully it should be through to me late next week. Install and tune should be done the following week, I'll post graphs as soon as I have them.
I'm running:
Blitz return flow
Trust PE II
3" dump + front pipes
Walbro 255lph direct wired
HKS pod + z32
4" Hard metal intake pipe
Bosch 1000cc's
MV Automatics Stage 2 kit - valve body + welsh plugs
Will probably end up needing new plugs and coilpack
Thanks mate,
Was this with the latest SS1PU or another model?
Regards,
Dazza
Status/Chequered dyno is about as accurate as you'll get. Conservative ramp rates and up-to-date correction methods means it will be very similar to DD results etc. I know that within melb, there's less than 5rwkw diff between the major DD shops and Trent's dyno.
So the numbers are very accurate.
I FEEL THAT THIS RESPONSE REQUIRES CAPITALS SO HERE GOES.
STAO/HYPERGEAR YOU HAVE SOME F**KING EXPLAINING TO DO
JUST GOT MY CAR DYNO TUNED - 306HP ON 14 PSI :@:@:@:@:@:@:@:@:@:@
MODS - ATR43 SS-1, JJR 3" BELL MOUTH DUMP, SINGLE CELL CAT, HKS HI POWER CAT BACK, JJR TURN FLOW INTERCOOLER, SPLITFIRE COIL PACKS, K&N PANEL FILTER, 3" STEEL INTAKE PIPE, TURBOSMART TYPE 3 PLUMB BACK BLOW OFF VALVE, WALBRO GSS-342, TURBOSMART BOOST T.
NO MATTER WHAT THE TUNER DID WITH THE BOOST CONTROL IT WOULD SPIKE TO 20 PSI THEN HOLD 14 PSI TO RED LINE.
TURBOSMART BOOST T.
Get rid of this piece of shit and it will not spike. They should be called turboSPIKE boost t. I've never seen one work properly, even on the lowest setting with 5cm of hosing they caused spiking on my turbo.
Also lose the attitude you sound like a spoilt kid with that post.
Edited by Rolls
I dont know how its Stao's fault. lol.
If it spiked at the top end it would be a different story. Perhaps you should sort out your boost control issues before defaming a business.
All of this. Especially the last part.
However I remember what it was like when I didn't make the power, I blamed Hypergear straight away too. Get rid of your craptastic boost controller and see how things go. 306hp @14psi isn't bad, these turbos only really come alive with higher boost. I'm sure you will see the power. don't start going off at Stao though, the man is legendary in going out of his way to help you.
I will blame him. The turbo has a 19psi actuator on it that he recommended and we only put the boost control on to try to keep the boost up. Without a boost control it does exactly the same thing. That power figure was without the boost t. From the day I received the turbo I told him it wouldnt work and he has repeatedly said no it's fine. Obviously it is not fine. If it was a boost control issue do you think I would be ranting about him.
Edited by lilcrash
Either a boost leak or exhaust leak would cause a boost drop that dramatic.
Can you pressure test the intake system and confirm you have no broken exhaust studs etc?
The turbo probably is fine and it is a set up related issue.
Edited by Rolls
There was one on my Soarer when I got it, spiked to >20psi at 1/4 throttle, first thing I did before driving back to canberra was rip it off.
    • About $4k brand new, available from vendors in Oz, or via an importer from Japan. Although that is for an R34 box, so you also need to buy the push clutch front plate (brand new from Nissan) and swap that over, and drill the bellhousing for a push clutch slave cylinder.
    • Absolutely could be. I collected data logs from when the O2 sensor was still out and also after I had replaced it so will try to compare them. Pretty confident that the affect is lowered with the new sensor, will check logs at the same RPMs/conditions.
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
