Yes, I'm currently making about 260rwkw. Thing is with sending off my turbo for Stao to modify, I live in Perth... So that's a huge down time for my daily confused.gif
I've got the G2, .64 housing. It's still just as quick, it still scares the pants off any mates that get in my car. It's just that I'm used to it now, 350rwhp got old quicker than I expected :(
No E85 in Perth, not at the pump anyway. I know forging won't give more power haha, I meant that when I can afford it I might forge and go for 500+.
Get a bigger rear, or get water meth injection and give it more boost and more timing!
If you are bored with the power take the car off the road for 2 months, it will be even faster than than when you first put the turbo on.
My car was off the road for 5 months, when I got it going again f**k me dead it was amazing, the handling was the first thing I really noticed but the power was scary after driving a 1.3L barina for all that time.
So the SS1PU makes 260-280kw depending on boost on the status dyno but I cant find any results on any other dynos or from actual customer cars.
I have ordered an SS1PU and im a little worried that it will not perform as reported. The only result I see in Sydney is from Sarge and thats for an SS2 with some setup related complications.
Can anyone share their SS1PU results on a dyno other than from status?
Dont have a dyno printout yet but 232rwkw on 14-15psi before coils started to breakdown.
(this will give you some idea of potential of the PU)
when new coils & plugs inserted will get retune to fix boost up to 19-20psi and will post up dyno
Regards,
Dazza
Edited by itshimdazza
Before going for the next tune, Please drive pass and swap for a 20psi actuator once you have the coil packs fixed.
I'm waiting for Stao to finish up on my SSv2, hopefully it should be through to me late next week. Install and tune should be done the following week, I'll post graphs as soon as I have them.
I'm running:
Blitz return flow
Trust PE II
3" dump + front pipes
Walbro 255lph direct wired
HKS pod + z32
4" Hard metal intake pipe
Bosch 1000cc's
MV Automatics Stage 2 kit - valve body + welsh plugs
Will probably end up needing new plugs and coilpack
Thanks mate,
Was this with the latest SS1PU or another model?
Regards,
Dazza
Status/Chequered dyno is about as accurate as you'll get. Conservative ramp rates and up-to-date correction methods means it will be very similar to DD results etc. I know that within melb, there's less than 5rwkw diff between the major DD shops and Trent's dyno.
So the numbers are very accurate.
I FEEL THAT THIS RESPONSE REQUIRES CAPITALS SO HERE GOES.
STAO/HYPERGEAR YOU HAVE SOME F**KING EXPLAINING TO DO
JUST GOT MY CAR DYNO TUNED - 306HP ON 14 PSI :@:@:@:@:@:@:@:@:@:@
MODS - ATR43 SS-1, JJR 3" BELL MOUTH DUMP, SINGLE CELL CAT, HKS HI POWER CAT BACK, JJR TURN FLOW INTERCOOLER, SPLITFIRE COIL PACKS, K&N PANEL FILTER, 3" STEEL INTAKE PIPE, TURBOSMART TYPE 3 PLUMB BACK BLOW OFF VALVE, WALBRO GSS-342, TURBOSMART BOOST T.
NO MATTER WHAT THE TUNER DID WITH THE BOOST CONTROL IT WOULD SPIKE TO 20 PSI THEN HOLD 14 PSI TO RED LINE.
TURBOSMART BOOST T.
Get rid of this piece of shit and it will not spike. They should be called turboSPIKE boost t. I've never seen one work properly, even on the lowest setting with 5cm of hosing they caused spiking on my turbo.
Also lose the attitude you sound like a spoilt kid with that post.
Edited by Rolls
I dont know how its Stao's fault. lol.
If it spiked at the top end it would be a different story. Perhaps you should sort out your boost control issues before defaming a business.
All of this. Especially the last part.
However I remember what it was like when I didn't make the power, I blamed Hypergear straight away too. Get rid of your craptastic boost controller and see how things go. 306hp @14psi isn't bad, these turbos only really come alive with higher boost. I'm sure you will see the power. don't start going off at Stao though, the man is legendary in going out of his way to help you.
I will blame him. The turbo has a 19psi actuator on it that he recommended and we only put the boost control on to try to keep the boost up. Without a boost control it does exactly the same thing. That power figure was without the boost t. From the day I received the turbo I told him it wouldnt work and he has repeatedly said no it's fine. Obviously it is not fine. If it was a boost control issue do you think I would be ranting about him.
Edited by lilcrash
Either a boost leak or exhaust leak would cause a boost drop that dramatic.
Can you pressure test the intake system and confirm you have no broken exhaust studs etc?
The turbo probably is fine and it is a set up related issue.
Edited by Rolls
There was one on my Soarer when I got it, spiked to >20psi at 1/4 throttle, first thing I did before driving back to canberra was rip it off.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
