Just remember to do it on a freeway lol, don't want anyone being arrested.
I was just gonna squirt it down the same road lol but Its better on the freeway because the road is smoother. 6krpm in 3rd gear is close to 140km/h. The car feels pretty dead coming from 1500rpm in 2nd, should be interesting to see how it goes from 3rd at 2k.
Yeah from 4900.
Dude.. It should be ON just after idle and OFF somewhere around 5... Turning it on at 5 would make your spool SUCK and your power rubbish. Please clarify the above?
& LOL @ the sarge in his army prints.
I just has a look in FC Edit and it only has VCT: then a value. For me it's 4700. Guessing it must be the switch off point as I can definitely hear my VCT solenoid click at just above idle when I give i give it a quick free rev. Can double check in sensor check later
Just for informations sake, specs on the corona.
1jz-gte
Hypergear TR44 turbo
Trust exhaust manifold
Trust 50mm wastegate
3" mandrel bent exhaust
500X300X76mm intercooler
3" intercooler piping
GFB Mach 1 BOV
2 front mounted gearbox oil coolers
Microtech LT12s and X6 igniter
X2 Excel radiator
No power steering or Air conditioning pumps
Techedge 2EO wideband o2 sensor
NOS kit (50 hp jets)
Greddy Profec B II
so it needs nos to get to 10.7? if so then what a useless post.
It did 11.8 without Nos. from that car's dyno reading:
The Nos added about 35kws. Those are old school turbos. The Fnt G3 he should be getting the same power curve without Nos.
Is this car still racing today?
Full boost at 2400 on a 2.5L, is that thanks to the stall converter?
My brother spools a 3037 .63 nearly at idle on a POS 2.6 Sigma. All thanks to a 2200rpm stall converter.
It ends up making all of 170kw at 18psi with the exhaust housing glowing white but it gives the illusion of a very different turbo.
Ahh the stall converter, applying load to the engine at idle to create some boost.
Here is a run from about 2500rpm to 6000rpm in 3rd gear on low boost(around 14psi). I know the dash isn't visible enough but this isn't something I want to try and do more than once on the road lol. My car seems to always ping now at high boost so I think the removal of the rubber hose has had an effect on the tune...
Edited by SargeRX8
You can find FNT feed back from Random in page 87. Check index on page 1.
Any way. lots of talk about twin scroll turbine housings. At this stage I'm not convinced that they has a "major" affect but welling to do some tests.
So, we all know the air gap inside the turbine housing is the height of the inducer blade of the turbine wheel.
By placing a metal strip in between and half the gap is actually reducing the area of the gap enabling higher air velocity. To me this is another way of sacrificing top end power for down low response unless the size of the turbine wheel and housing is in a reasonably large size.
Theoretically I can archive this behavior by reducing the gap height at only 60~70% of the turbine wheel top without the divider in the center.
I've done a drawing converting single scrolled turbine housing into a twin scroll item, internal or dual gate bolt on to stock setup of course. Good thing is I can setup dual effective FNT nozzles inside that housing for even better response. I'll be doing a back to back tests using a G3 core. hopefully it’s worth the effort.
Any way, Do post up if you have any experiences or back to back tests with single to twin scroll turbine housings.
    • Ok so will run the piping over that radiator and no plenum it is. Put that money towards a Haltech and see what suits. Any ideas something like an elite 2000 or 2500 right? My long term goal is 300kw e85 and manual swap and that’s a dream come true. For now will be 200kw and auto the stock rb25det neo intake isn’t too expensive with throttle body. If I was to have the port matching done, Would that be better than the stock de intake as the det has bigger holes plus has the spots for sensors etc? And suit more long term?  appreciate the advice?
    • You understand AFR is not the only thing that contributes to it pinging yeah? Funnily, what the AFR gauge will tell you when it likely is pinging, is going to make you think things are really safe and good.
    • Run the piping how we all have for decades. Also the duel runners with the +T setup dramatically helps it gets on boost quicker. Yes, chase huge power it'll become a problem, but you're a long way off when you're already saying an aftermarket ECU is out of the budget. You also say NisTune as it's simple, and then immediately say it'll be painful, meaning... It won't be simple. It will likely cost you a lot more stuffing around with a Nistune, than just putting a Haltech or similar in.
    • I’ll order an afr gauge to keep an eye on it.  Then will get a haltech soon
    • TD05 or maybe pulsar PSR2867r Gen 2?  id love a garret but it’s quite out the budget for now and I’m not chasing crazy power.    yeh fuel pump haven’t looked into but whatever works, kind of last on my list.    Nistune because it’s simple but Ik it’s a lot of pain especially as I’m auto +t with the whole seperate TCM etc still investigating that. Haltech id love but once budget tight for now atleast.    finally the reason I’m trying for a plenum instead of the stock intake is I already have a standard Intercooler mounted etc. so the ports are on both sides so trying to not have to go over the clutch fan radiator etc. trying to find a good deal return flow if I don’t than this will do for now I guess. btw any ideas with that, apparently some people have to cut blades to reduce it from hitting the Intercooler piping over the radiator ? Thanks
