Ok I've now fixed my air leak (loose hose clamp), changed exhaust and removed the boost control. Still getting 22psi dropping to 14psi by redline. Stao can you send me a stronger actuator to try.
Was that with the air box lid and filter off?
I couldn't suggest running without a filter. I had a 1mm gap between the gasket in my apexi filter and z32 and enough shit got in to damage the turbo fins. Silly idea. At least put a stocking over the box snuggly so at least you know some shit wont go in.
One run down the street should be fine surely? Just don't drive through gravel or anything like that. I'd be more worried about the sock getting eaten.
Edited by Rolls
So has anyone got their SS1PU fully tuned with dyno results yet?
I got mine in the mail yesterday, should be fitting it this week.
Yeah, 260rwkw on 19psi, stock internals. Dyno vid is on youtube :)
xxswitchfloxx
Mods are on there also. I might have a dyno pic lying around too ill post up in a sec
xxswitchfloxx
Thanks mate - dyno would be awesome, esp with the boost. Does it hold 19psi all the way or run more/less in the midrange/top end?
Whats it like to drive?
19psi at like 3500-3700+ rpm, then dies down to 17psi by redline.
Stao mentioned i use the screws that came with it to stop the boost dropping, some sort of airflow changing method. Not sure how it works, but seeing as its a pain in the arse to get the turbo off theres no way i have the time to take it off continuously to see how far each screw needs to be turned for the boost to stay level. Not to mention the time it takes for the turbo to cool down enough to touch..
Very fun to drive, not the best top end acceleration but that's not what i wanted. This is my daily driver, so i wanted low end power and that's what i got.
Spinning wheels in first and second and get sucked in the seat :)
Keep in mind, those results were after a lot of runs, so heat-soak set in. I reckon on a cold day + first try it would make over 260.
Has anyone been in a car with a atr43 g3 and atr43 ss1. I'm considering upgrading from the ss1 to the g3 and just wanted to know what people think of the difference.
Do you need to upgrade or do you need to work out your issue?
IIRC your already making the projected power for the SS1 though arent you? Being 240kwasps
It's just a possible solution to the boost drop, stao has suggested the upgrade or a bigger actuator. But I'm deffinately not happy with the power but i don't think that it is the turbo. My tune is all over the place.
Edited by lilcrash
Do u have a dyno graph lilcrash?
I have done a g3 on a 34 but maxed the stock injectors at 232kw 19psi 6000rpm
And dynafits ss1.5 259kw 19psi with weak clutch
I have had both on my car with exactly the same mods. They are completely opposite turbos. The ATR43G3 was over 1000rpm less responsive then the SS1, was a HUGE difference. I was able to make 280rwkw with the ATR43G3 and 245rwkw with the SS1. The SS1 is way better for the street, standard turbo like response. I now use E85 fuel and make 280rwkw with the awesome response.
On both turbos my boost would drop to 15.5psi no matter what I did, boost controller, wastegate studs etc. I found replacing my intercooler and fixing up the exhaust helped as now boost only drops to 17.5psi. So for me it was other restrictions in the setup that were holding back the boost up top.
If you wanted to go bigger I would stick with the SS range, either the SS1PU or the SS2. I thought the ATR43G3 was too laggy for a street rb25. The SS2 is around 3-500rpm more responsive then the ATR43G3.
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
