Hey guys
Will it do any damage or cause any trouble if I put the SS1PU on without the nistune installed yet?
Trying to work out a way I can get the car to DVS without having to tow it up there.
I was thinking install the SS1PU and then get my brother to wire up a plug for my z32 so I can drive up with the stock AFM then just chuck the Z32 when I get there
how far are you going to be driving, isn't DVS a couple hours away?
It's very possible not to boost lol. If you want to install the turbo before you get it tuned then you don't boost it, simple.
On the stock ecu it will hardly boost before it hits r&r anyway.
I ran my ATR43G3 for a year without being tunned ran it on 7 psi and its ran great just laggy.
Loosen off the actuator so its sloppy comming on boost and you will be fine hitting up to 5 psi on stock tune
Possibly get a base tune by someone in Canberra and let the turbo run in, then go to DVS to get the tune tweaked?
If money is a factor, work out if it'll more $$$ to tow 4 hours or get a base tune here and drive up.
Hey guys
You will be fine. If the turbo is the only aftermarket thing you've got on there, it will be fine. 4 hours of tow truck.... gonna cost you. You can easily drive the full speed limits. Going up to his place is pretty easy, no pressure to floor it or go fast. Once you are on the free way cruise it there. Get all the prep work done before hand(as you are with the wiring) so when you get there and get to the dyno, minimal time is wasted dicking around.
I drove my car to my tuner about 20 minutes away first time. I had all my aftermarket parts in there except my injectors(didn't want to risk the wrong settings). It was running on the base tune with the z32 afm and it was fine. This drive was through start and stop traffic.
I can probably drive my car to the other side of australia at 110km/h without hitting any boost at all. Right foot, control and toot on. You won't hit 6psi unless you actually tried to. You'll be fine man trust me. You will get there faster than a tow truck will and you will have the money in your pocket to pay for the tune or pay for something else when the car isn't making the power it should.
Yeah he is at least 4 and a half hours away which is impossible not to boost
What kind of issues does it cause upgrading from stock turbo with the stock ecu.
Thanks guys
If you boost it you risk detonation, however what you can do is leave the wastegate actuator off so you literally can't boost more than 1-2psi by redline, do this.
ive been driving with my gtx3076 and stockish tune, cant do more than 2-3psi without the engine light coming on, you should be able to baby it around no probs
just change gear at 2500rpm with not much throttle, mine still keeps up with traffic even off boost, just shift up quickly and your fine.
taking the actuator off will make it sound very loud and drive like a dog, atleast thats what happened with mine.:whistling:
The turbo it self acts like a muffler of some sort, bypassing the turbine the exhaust goes through the open wastegate, it will be louder. It will run like arse, but its foolproof and safe if you are worried about foot control.
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
