Just a note. The excedy heavy duty can't hold 200kw.
Holding over 300kw (flywheel, where the rating is measured) without a problem for me. Don't spread misinformation.
Agree the Xtreme Motorsport clutches have also worked very well for me.
A car Ive done previously had the Xtreme button plate wear a little thin so I popped a regular exedy organic plate in it and its been running forevermore another 18 months of abuse later.
Here is a 34 i just finished tuning. Did a run before poncams and then tuned it after poncams.
Is running G3 older spec. This is with profec B spec 2 set to 0 but helping with holding top end (basically gate pressure)
Tao has sent a 14psi actuator that we will fit so can tune a low boost.
I tried more boost with this setup but kept nosing over and for the extra amount of boost there wasnt enough gain.
It saw 281kw with a bit more midrange on 21psi.
Tried advancing and retarding exhaust gear with no gain. So left at 0.
Also tried dropping the exhaust which automatically raised the boost to 20psi and made 281kw
Thats correct coupe.
The light blue run was when the dyno was playing up but it was reading the dyno correctly just not controlling the steady state.
I have tuned this car in the other (mainline) dyno and it made 232kw but has a different cat since then
Aparently I was lying before so here is the full details. I've got an rs4s running an excedy hd, stock turbo on 10/11psi it slipped a little, installed hypergear tuned to 220kw, slipped a bit more. Rebuilt engine and got clutch checked, nothing physically wrong with it or the flywheel, just doesn't hold.
thats does it I want cams now...
Oh wow. Am I reading the graph correctly in that the run with poncams made 53kw more top-end (ignoring the mid-range gain as well because I can't see that axis) with less boost? If that's the case then I may start thinking about poncams more seriously as well lol. What are the specs on those cams, are they Type-B's, ie. 260's???
I also agree it looks like a restriction somewhere though, what's going on with the shape of the curve Jez, was that caused by the exhaust?
Lol very true, between boost bleeding off, square wheels and my brake pedal causing earthquakes in my car. I'm having lots of fun chasing problems.
You were lying before, so how can I trust what you're saying now? :P
Seriously though, there are a lot of factors to clutches not holding up in specific applications. Your pressure plate may be worn which can be visually impossible to tell and the lack of clamping pressure, no matter how good your friction plate is, will mean slippage.
no u dont, what you (me also) need to do is get VCT running so we can get a fatter mid range! lol
Yeh but I'm already onto that and it hasn't costed me any money yet, that's no fun! :P
By the way, hoping to have results for my latest setup around the middle to end of this month. Just need to get my throttle cable issue sorted and then I'll book it in for a tune. VCT should now be working, so fingers crossed I've got it all right this time haha.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
