That's an awesome result for the SS3! Anyone wanna compare that to a Kando graph? Looks like similar power but less lag? (going by my not so reliable memory)
If you don't mind telling me what people these electric turbos will be marketed towards?
Because I swear it's better/ more satisfying just having a turbo car
I believe the primary intention is to use it with a 600+ HP turbo and feel like it has no lag. Like a cheaper less complex compound system.
And yes that SS3EG looks epic! The price is great too!
Only problem is, for such a large unit it is only making 1psi +ve pressue
A good ram air system can do that
1psi = 2.036"hg
so if it is going from -5 on the boost bauge (most boost gauges read vacuum in InHg) it has made 7InHg difference
My feeling is, that if you took the electric blower out of the intake and ran the car with just an intake pipe the difference would be even less.
Stao, have you thought about using a compressor out of a centrifugial supercharger? They are designed to use less shaft RPM to flow the air.
If you can get the electric blower to move a heap of air at low shaft rpm you could be onto a winner
Problem is, if you can't find a way to refuel the batteries running the electric blower, then it's just a charge and use system...like meth/water injection, or NOS...only less efficient. And the latter of which I thought was already used to combat lag in big turbo setups?
half the reason it looks epic is cause its an ex gate..
So is the Kando I'm comparing it to :ninja:
Actually, your on a good track here......
Stao, why dont you produce a belt driven suppercharger and setup a twin charge system? If you made an affordable kit you might actually do really well from it. I think what your doing now is on a similar sort of track, you just need the gearing.
Hey if it worked and was a bolt on to my motor (im SR but hello RB25 SAU) I would definitely buy it and run it with a much larger turbo. Hell, you could supply both.
No there is no lag in the electric system. The eturbo spools up and reaches surging point straight way. The key to this is not all RPMs it needs torque. I'm looking to buy an higher powered motor soon. hopefully that can make 3~5psi.
Belt drive... Compound turbo....
Agree^
If you can compound it...so run a belt drive from engine to a gearbox that multiplies RPM for the turbo shaft. On the engine side of things, have an A/C compressor style clutch that disengages electronically at a certain RPM, where exhaust gases take over...is there a reason this wouldn't work?
Actually I wouldn't mind a centrifugal blower setup by itself just to be different, however inefficient it may be compared to a turbo...is this something you could produce Stao?
Agree^
Thats how it works for all the factory twin charged cars :)
Yeah, except that centrifugal superchargers that are belt driven from the engine don't make any boost at low revs. They need some shaft speed under their belt to make any boost at all, and only make their max boost at the fastest shaft speed. Which is a bit gay for a super-turbo compound setup, because what you really want is for the supercharger to be making boost instantly at the bottom of the rev range, which then leads on to all the benefits that you actually want from the system (which is more off idle torque, reduced pressure ratios across each stage of the compression setup, larger rear housing on the turbo stage to reduce back pressure and reversion and all that, etc, etc, etc).
The only way this discussion makes sense is if you get;
  1. A belt driven geared up electric supercharger that switches off and out of the flow circuit once the real turbo is up to speed (so, sequential really, but it could start out as compound series, and when it switches off and out the main turbo becomes conventional).
  2. A belt driven lobed blower in normal series compound arrangement with the turbo, a la what Stockymcstock did. Packaging all that stuff into the engine bay is a pain in the arse though.
Im sure a really well designed compressor with appropriate gearing could start boosting at a decent RPM and not go into surge or start blowing hot air by redline.
The idea is to compress compressed air anyway, so as long as the compressor doesnt surge or blow hot it just needs to keep compressing what the turbo is giving once its out of its efficiency range. So it should be fairly doable in my mind.
its more or less like this:
intake - big turbo inlet, big turbo outlet - supercharger inlet, supercharger outlet to intercooler and so on. The idea is to help the big turbo spin up sooner. The main restriction in a compound setup is the small housing on the small turbo, but thats a null point in this case.
Should be fun if Stao takes it on board.
I see. I always thought twin charged was done as seperate units, i.e. a blower atop the engine, fed by a turbo further down the plumbing, rather than combined into one housing.
Examples of factory twin charged cars?!?
Nissan March Super Turbo
The Lancia Delta's
there are a few others but cant think of them right now
Why not just use compressed air from a compressor to spool..
Would be as simple as plumbing a nozzle into the turbine (and or compressor) and having a solenoid rigged to open at desired rev range to keep turbo always on positive boost..you could even rig it so that the solenoid opens whenever turbo hits negative..
Seems pretty simple to me now you guys tell me why it won't work...
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
