To keep this thread on track I wonder if Hypergear and Scotty NM35 join forces to start making a bolt on package together that you can buy your turbo and custom made air intake piping etc so that u have everything you need straight up to get the car. After all if hypergear gets a few made up it should be able to reduce the price for customers.
I would be keen, and doing bulk runs would bring the cost down a little but at the end of the day there aren't many of these selling, not enough to warrant getting cnc mandrel piping and bov bungs made anyway. Added to that, everyone wants a different product, some for stock airbox others for pods, some want breathers some don't.
The basic pipe I can do much cheaper its the added labour costs involved in die grinding the hole, making the bungs that have to be manually turned on the lathe then tigged at tight angles, die grinding/cleaning up inside the pipe etc. Yes you end up with a much better and legal design but it obviously must cost more, I only charge for my labour, no profit margin here.
I was thinking of getting the pipes made in China in bulk but they would just under cut me through ebay like so many other manufacturers have found. No point.
Eco crap had nearly ruined the thread :P
Stao probably invented 3 new turbos while we weren't paying attention lol
Has the work with VNT Turbos got far yet? ATM I'm thinking a g2.5 looks the go but a VNT would be awesome
the Eco friendly chat is cool. I don't mind carbon tax and what ever the labor's trying to do
You have a PM ;)
P.S. the rb25 gets fare too much attention please develop a cnc bilit for the little o'le 20
You have a PM ;)
if it's carbon pricing related, do share... wouldn't want Stao to be misinformed would we ;), already had a few common myths trotted out in this thread already ;)
is anything else happening on the variable vane front Stao? or is that on the back-burner at this stage?
Also:
Uploading some video footages from 3 weeks ago regarding to the Prototype ATR43G3 Alfa ceramic ball bearing turbo. One of the injector went funny towards the end of that run, the best it made was 334rwkws on 22psi of boost. Didn't get the sheet, will go back with it again with aftermarket manifold, new injectors and more boost.
For now:
Are there more stories on this shinny roller bearing turbo? Ever throught of using this on your new SS2?
Its too expansive to build plus not much difference in performance. So I will leave that project for the time been.
Status is getting their dyno fixed today, so assume every thing goes well, I should have some results from the new SS2 turbo on monday.
I'm excited :) I'm almost ready to drop engine back in but will send it back Wednesday if results are good
Some updates:
I've finally managed to start the car, for some reason it was much harder to get the E85 started when the weather is cold. It is other wise in a worm day. unfortunately this years Melbourne winter is pretty cold.
The new turbo using less weighted material driven nicely and responsively on road with the G2.5 tune, with plenty of 3rd gear wheel spinning action. I believe this is the most responsive turbo using .82 type B turbine housing internally gated so far. Hopefully producing similar power as the G2.5 while providing SS1PU's response.
Interestingly or not, E85 appeared to be a much cleaner fuel then 98. I have taken some photos from the G2.5's rear housing and turbine shaft when it was re-made into the current SS2. They are clean, while 98 would leave a firm layer of black carbon.
Note: The black mark on the turbine wheel is carbon mark. No one will ever get a cracked turbine wheel from here.
Only the new SS2 if works well, you are welcome to send in yours for update free. SS1PU is probably in about a week time, running the comp wheel machined using the same material. I will also be doing lot of tuning and work for the turbo kia project.
Trent's tuning it on Monday. Likely I will be keeping it on E85, possibly few runs on 98 depending on how the time goes.
Is E85 relevant to most people interested in your turbos?
I'd love to hear people's thoughts on this.
I'm very keen to strap an HG to my Stag sometime this year, but certainly won't be going with E85 due to it's limited availability.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
