Some updates:
I've finally managed to start the car, for some reason it was much harder to get the E85 started when the weather is cold. It is other wise in a worm day. unfortunately this years Melbourne winter is pretty cold.
It is often hard to start E85 in winter due to the lean mix of unleaded petrol. This is primarily why E70 exists and E-flex is supposed to have an enriched unleaded content during winter.
Some result from the new SS2, only had time to do a touch up on my E70 tune and my fuel pump is at its limit. I will need a bigger pump for the E70 to finish off the power run in couple of weeks time. For time been it made 345rwkws at 19psi bleeding down from 22psi. Likely there is another 15KWs gain using a high pressured actuator holding 20psi up top with more fuel. It is currently running the lever mode with a 14psi actuator.
For some reason the lighter material did not alter much in boost response on paper, how ever managed to produce heaps more mid range in comparison to the G2.5 that made similar power output. The difference is very noticeable on road, does not feel laggy at all.
The prediction on pump 98 would be around the 285~300rwkws mark as the capacity of the Type B .82 rear housing is up to the 300rwkws mark.
There was only enough time for a touch up today. I will do 98 run when I get the fuel pump replaced.
Here are some video footages taken from today. Note the difference in sound between the light weight billet comp wheel to the traditional cast and 7075 billet wheel. It came in very early, how ever on paper it doesn't show much.
thats not a bad result, its quite nice.. however that is on E70............. please retune on 98 to make it a usable reslt
Agreed. Looks mint but e85 is too hard for me to get.
Thanks for the offer Stao but I won't be sending mine back for the update. Will just bolt it up as is.
Thanks again
+1 ^^^
Where's the ethanol love? Usable result for who? Its Stao's car not yours Scott and he wants the powah. :P
It sounds like they all jelly Artz...
maybe he should re tune on 91 octane so it can be a good result for all the complete wankers out there lol.
should he run low boost aswell just incase ppl who buy one of these turbos dont want to run the boost he is testing on??
Edit. I won't say it in here. That wouldn't be fair on him with his potential future customers.
Edited by lilcrash
looks perfectly usable to me , now stop your sooking :P
+1 ^^^
Yeah, lets showcase how good a turbo runs on ethanol when 95% of the customer base is running 98.
:no:
:no:
I think you would be surprised, its not 95% mate, and there is a growing percentage switching over these days.
Stao is in Melbourne, half his customers down here are on ethanol or plan to run it. Just take 40kw off the graph if you need the 98 figures.
Ask Trent what percentage of his tunes are e85, I would guess at 30-40%. Get with the times... :)
All well and good to take off 40kw, but ethanol changes the whole curve. You would essentially be guessing at how the turbo would perform on 98, and I don't know about you but I wouldn't buy a turbo where I have to estimate how it's going to perform.
I think testing on ethanol is fine, and it is very interesting, but I still think Stao should get results on 98 as well, otherwise it makes diagnosing potential problems very difficult. I mean, we've seen how many people in this thread, including myself, have had substandard setups and not made the expected results. Stao has always been extremely helpful on this front, but what happens when customers start buying these turbos that have been tested on ethanol based on an estimation of how it will perform on 98 but then don't get the expected result? Is it a case of underestimating the effect that ethanol had, or are there other issues?
No point sooking about it. I want e85 results. :P
Do GCG or MTQ do any testing and post it up for all to see? How is it Stao's obligation?
Lol, not sooking, just discussing. It hardly matters to me, I've already got my turbo. That said, I did ditch my previous G2 based on the result of the G3 in here...
It's not. He isn't obligated to post any of his results, I'm not saying he is. I'm simply voicing my opinion as a previous Hypergear customer, it was the results in this thread that convinced me to buy one.
Its not his obligation, and i still applaud the mans work through and through, but that was my opinion.
VIC might be lucky (and full of fags :P) but NSW and WA are suffering without a reasonable ethanol supply at this stage.
Anyway lets not get into it. Believe me I WANT E85...... It would save me the rebuild im in the middle of right now.. But it aint happening quick enough to warrant letting my car sit around unused or half tuned for ages.
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
    • Yeah Jap import. Fairlady Z then! I'm a bit the same.  They've been on my radar for a fair while but then just impulsively decided to buy one!  Was going to just buy an NA and add turbos to it later but decided to save the f'ing around and just buy the turbo version.
