Stao, in your eyes, what would work best if you had 2 options with the ss2, a internal gate ss2 on a brea manifold..or a external
gate ss2 with ext gate put on stock manifold?
cheers
darren
At this power level if using stock mani port matching etc I would imagine to make quite a difference. Pretty sure Abe with G3 port matched and was 350-360kw
Further updates. This is the 2nd SS2 prototype been trailed. More responsive and made more power to previous version. Internally gated.
Max of 312rwkws on BP 98 and 210rwkws by 4000RPMs
Stao is this 100% 98 fuel or could there have still been e85 in the tank for the comparison? The difference between all ss2 models at 3700 is huge with this version way in front!!
Stao do u supply an external gate n low mount turbo package(no brea manifold), if so, what gate is it and how much for package and also for gate separately? Good quality gate?
This has been on my mind
I didnt even give that a thought, buy It's probably highly likely there is eflex still in the tank, because I doubt the tank was drained between the different runs.
It would account for why there is such a large improvement over previous ss2's. I'm sure part of the improvement is also down to stao re engineering housings/wheels as well though!
The e85 has been drained by the fuel pump. And filled up with 20l of 98. Difference was about 10 degrees of timing. The 98 runs appears to be slightly more responsive.
So potentially there could have been 2 or 3 litres in tank before adding 98. If so next time you fill up it might start pinging?
I drained mine off the pump other day and I could still see fuel. I only just got new Bosch pump and weather has been too crap to see how much is left in there. But at least a litre minimum maybe 2
Yeah easily. When i convert to e85 normally have to run 20litres of e85 to help flush the left over 98 then refuel e85 and finish tune
Well my car's on E85 full time now. It keeps every thing clean including engine oil, and E85 servo is just 500 meters off road from where I am. My current pump is wabro with a rubber fuel pickup hanging off the bottom, there could be a 1L of E85 diluted into 20L of 98.
E85 generally makes a average 40kws more then 98 then lets say it maxes at 300rwkws on pure 98 on my setup, generally means maximum of 280rwkw when fitted on stock manifold internally gated.
Either way I'm pretty happy with the final result as it had the most area under the curve for the power level it archived, with brilliant road drivability.
If only it was that simple!
Mitch tax time!!
Then you and I are road tripping to Jez's for a tune on this magic juice.
Stao what would you expect the SS1PU to be pulling on e85 stock manifold.
280-290? Or will it max out
Chuck it on your car and show me haha
Mitch tax time!!
Have you thought about how youre going to get home, because it's 400 odd kms and I don't think you will make it on one tank of e85. Is there a servo on the highway that sells it?
Might have to carry a few jerry cans with you?
Edited by Mitcho_7
Well, there are no differences in fuel between the two runs, They all been drained out through the fuel pump, and the pump had a rubber pickup that sit on the bottom of the tank. So the fuel are identical. The 98 was carried in 20L drums and removed on the end of the run using same method. The tank is then filled up with E85 again.
    • Hey crew, Failed my WOF cause of a lower control arm, and I've decided to hit both arms, and also the compression rods at the same time(seems they're gonna be the most likely upcoming failure points from some discussions with the lads over on the G35 reddit). I've looking at these form Z1:  https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-compression-rod-p-40716.html https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-lower-control-arm-p-40674.html I asked Z1 if they'd work as it's the same platform, just RHD vs LHD. I basically got told "Lol dunno". Specifically they aren't aware of any difference but can't guarantee fitment as they haven't done it on a 350GT. So guess I'm asking is if there is any issues with using 2005 G35 coupe suspension parts on a 2005 350GT coupe? Orginally I thought it could be something in the way of the arms that each control arm is designed to be positioned around, but that'd be an engineering nightmare for Nissan needing two different shaped control arms 😅
    • ^ This. The mode door actuator is a common failure, as is the actuator and/or the actual valve for the coolant flow control valve. I also don't know how available the mode door actuator is these days. I've been meaning to look into it and get one from wherever is possible, to keep in the shed for the rainy day when mine eventually fails. Anyway, the advice to you is to search the usual NOS part supply places, or even just go to Nissan and see what they list.
    • Have you got a pic of the actuator? My guess is that unit has failed internally and was flopping around, so the previous engineer who owned it forced it to be fully open to cold air (blocking the heater core path). As far as you can tell, is anything else wrong in the system? Likely you just need a new actuator (not sure how available they are) and then "installation is the reverse of disassembly"
    • I'm happy with the Lsailt unit that I put in, it puts full Android on the top screen so you can run whatever Nav and other Apps you want, while still existing inside the factory functionality like automatic reverse cams, audio input switching, retains factory bluetooth etc. Not cheap and the install was moderate (not simple, not hard) Yours is a V36 not V37 though right?
    • Yeap, all the NC's that I originally looked at that had a hard top were PRHT, which makes the roof line look horrible, hence why I said nope to them My only caveat for another MX5 was it needed to have a hard top, and initially I didn't think you could get a detachable hard top for the NC,  like my NB had Again, a big thanks to Matty for helping me source the detachable hard top for my little girl, they are as rare as hens teeth in Australia, and the few people who have them, keep them Also to Greg, for initially pointing me in the NC direction NC PRHT 🤢🤮 Not mine (I really should take more photos of my car), but a NC with the detachable hard top 😁 To me, the difference in how the detachable hard top roof line looks, and how it actually follows the bodies lines, like they do on NA's and NB's, is chalk and cheese compared to the bulbous looking PRHT
