I got 280kw at 16psi at 6000rpm. I had no cat. If im correct u had a cat in ur exhaust system?.....Get rid of the cat and I can almost guarantee you will see around 20rwkw gain and response gain as there is less back pressure on exhaust wheel.
Edited by adam999111
I've got something like this
http://justjap.com/store/product.php?productid=18066&cat=&page=1
Will order a mid muffler prob tomorrow or fri and see if I can fix it all up before I go to Japan then make appointment for when I get back for another run. Just wish it wasn't 2 hrs to tuner. Driving through the city with a twin plate was a nightmare.
How far back was your dyno sheet Adam?
Edited by t_revz
Based on what exactly? There is barely 5hp difference between my car with the exhaust on vs off...
http://justjap.com/s...066&cat=&page=1
My dyno sheet is on page 292. that power and psi i stated was actually at 6200ish rather than 6000, mind you its did make just over 290 before some timing was backed off.
Based on the laws off physics.. In an Ideal world nothing after the dump on the turbo, will obtain the best results performance wise. any restriction in the exhaust is going to result in power loss, thats inarguable, its just when the gains don't become significant enough to worry about. Please dont get hung up on numbers, it might not be exactly 20kw... As with your exhuast, it must be a good free flowing one
On the same time you are also running an external gate. I've also made 290rwkws on 19psi peek at 6200rpms at 17psi on the same turbo externally gated off the turbine housing. It some appears the external gate has greater gain used on stock exhaust manifold.
that's quite a restrictive cat once it warms up
Only when it's warm? ^^^
when the core heats up, becomes an exhaust restriction, this easily can be done with a few squirts on throttle on full song.
yeh sorry i keep forgetting i have ext gate and t_revz is internal, but he will still see gains non the less without at cat.
Will also see some decent fines from the EPA if caught :)
Soon enough it will be free flowing. Just have to find a suitable muffler to compensate noise and bring it down quite a bit
I might be biased here, but HKS Super dragger, it's dead quiet man. Seriously not much louder than a stock VL 3.0..
I've used Apexi N1, HKS Hi Power, DRIFT, St Mays all on RBs, and the HKS Super Dragger has been the most quiet one.
Why would it only be a restriction when it's hot? The substrate doesn't change, it just gets hot...
Eh, we're in WA ;)
Yeah that's a good point. Easy to check too. I can fully understand not making as much as ex gate versions up top but should be close as I've got extensive head work and cams etc but I would think midrange should be near identical. But looking at boost I have 13psi at 3700 while Stao's latest was at 21 so no wonder it's 110hp lower.
Going to check actuator preload next day off and see if that's ok too. Try to double check VCT ASAP. Come to think of it I haven't heard the solenoid clicking like it used to. Vct obviously affects boost curve in a big way?
Vct is practically make or break for an RB25 on vct based cams.
if that's not working deduct something like 1000rpm for boost threshold. its silly.
Well it was done but cos I dropped the car off before Sean got there and we didn't chat he set boost to 18psi max and very safe. Only made 340hp but he told me to ignore the number as he can never reproduce Hp numbers that hypergear customers expect. So I drove home and gave it a couple squirts and it feels good. Maybe it was similar power but just low reading dyno...until I compared my result to previous results and it seems lazy on boost. Might need more preload. So thinking of taking it back after doing the exhaust and Sean said we can try put 21+ down its throat
Any other thoughts? Mine is red
Power
Boost
That's a little disappointing...
    • Yep, there's a very minor drift left that happens a few seconds after letting go of the steering wheel, but not enough to bother me. Enjoying the car still!
    • Got you mate. Check your email!
    • I see you've never had to push start your own car... You could save some weight right now...
    • Sounds good.  I don't 100% understand what your getting at here. When you say, "I keep seeing YouTube videos where people have new paint and primer land on the old clearcoat that isn't even dulled down" do you mean this - there is a panel with factory paint, without any prep work, they paint the entire panel with primer, then colour then clear?  If that's what you mean, sure it will "stick" for a year, 2 years, maybe 3 years? Who knows. But at some stage it will flake off and when it does it's going to come off in huge chunks and look horrific.  Of course read your technical data sheet for your paint, but generally speaking, you can apply primer to a scuffed/prepped clear coat. Generally speaking, I wouldn't do this. I would scuff/prep the clear and then lay colour then clear. Adding the primer to these steps just adds cost and time. It will stick to the clear coat provided it has been appropriately scuffed/prepped first.  When you say, "but the new paint is landing on the old clearcoat" I am imagining someone not masking up the car and just letting overspray go wherever it wants. Surely this isn't what you mean?  So I'll assume the following scenario - there is a small scratch. The person manages to somehow fill the scratch and now has a perfectly flat surface. They then spray colour and clear over this small masked off section of the car. Is this what you mean? If this is the case, yes the new paint will eventually flake off in X number of years time.  The easy solution is to scuff/prep all of the paint that hasn't been masked off in the repair area then lay the paint.  So you want to prep the surface, lay primer, then lay filler, then lay primer, then colour, then clear?  Life seems so much simpler if you prep, fill, primer, colour then clear.  There are very few reasons to go to bare metal. Chasing rust is a good example of why you'd go to bare metal.  A simple dent, there is no way in hell I'm going to bare metal for that repair. I've got enough on my plate without creating extra work for myself lol.
