This project is mainly for Greddy turbo fans, but I don't like copying them in OEM specifications, so I will mix and match wheels plus some customized profiled billet wheels for them to be different. The goal is for dynamic drivability, Modify housings to fit different types of vehicles, and perhaps adding ceramic roller bearing cartridges.
I'll be keen on getting one if it outperforms the standard td05 without the billet wheel as that's what I have now
Also my friend had a td06sl2 in those housings and had trouble controlling boost kept creeping have you fixed this problem by porting the gate or reccommend external gate with the td06
I've had the T518Z billet version finalized today with every thing machined up nicely.
It is currently on 18G compressor with a TD05H turbine. I will machine one more housing using SL2 turbine tomorrow
Depending how they go, you could potentially open up a nice little market for those turbos. I didn't really think about it before, but i was
thinking today
due to all the chinese exhaust housings for these mitsubishi stuff theres a ready made market for subarus in both twin scroll and single,
evos, RB's ,CA, SR, might be others i havnt noticed.
be very interesting to see how your modified versions went on those other vehicles compared to the stock variants
Anyway nice work
cheers
darren
i still don't understand how there are so many nice cast rear housings for the sr20 5bolt dump pattern
yet there are none for the rb20/25 one, stao has to use an adapter to make the 6 bolt dump
I just don't see how Stao can make that adapter cheaper than a nice stainless dump, it's quite a chunk of steel and plenty of machining work just to re-use the dump that may be fitted already.
Surely a 5 bolt stainless dump to fit up to the stock three bolt flange, in 3 inch would be cheaper, lighter and flow better?
So after a weekend of fitting the turbo, apart from the aftermarket manifold fun which set us back 4-5 hours everything was smooth sailing.
Water line was a quick fix and apart from one the of the oil fittings now being short, job was pretty straight forward. Helps having a mate that sorta does it for a living and a workshop at your disposal though.
One issue I am having though and I think other people have had is the dump pipe now sits up hard against a particular rubber house. Air con house or something I think?
Picture below:
What have people done to overcome this?
Being a track car, that rubber hose and whatever is under there is going to burn in about 5 minutes.
Exhaust lagging on the dump with it doubled up where it passes the hose but I'm looking at cutting the dump in half and rewelding at a different angle to avoid the hose and raise the lowest part of the dump.
Prob pull it off next weekend and start figuring it out.
That's the issue with spacing the dump back an inch, it gets pushed back into that aircon drain.
Try some heat shield around the rubber and wrap the dump. Might last a little while before it leaks into the car...
Well I believe the current ATR28 turbine wheels are much better turbine wheel to the TD05H, if it doesn't perform as planed then I will change it. Regarding to the wastegate flapper, I will fit a large 38mm gate to this housing.
That manifold sticks out about 20mms compare to stock, plus I think the JJR dumps do have the issue touching drain pipe. The pipe needs to be zip tied backwards or wrapped with heat wraps.
Hrmm ill see what I can do.
I'll double check but Im pretty sure its hard up right against the entrance hole, so there isn't much movement in trying to tie it hard against the chasis.
Heat wrap might last one session at Sandown Scotty lol
Anyway I've left it with my mate to have a think about what we do :/
Do you need air con for a track car?
Maybe just get rid of it and bypas the hose or something.
It's a track car but still my daily :/
I melted that hose log ago and have had 0 issues with it. Still getting an icy 18 degrees and no water leaks :D
Well that's intradasting.
We might cut another or bigger hole and loop it through.
Will let you guys know what we eventually do!
Hey Stao
Quick question. Do you know if Trent will adjust the boost via the adjustable actuator you have provided on the turbo or via a turbotech boost T that I currently have on the car?
If he just uses the adjustable actuator to control boost ill rip out the boost T out of the car.
Adjustable actuator? Unless there are different springs that come with it... Don't change the threaded shaft position. It needs to have around 3mm of preload, it isn't for adjusting boost.
He would normally adjust it through the boost controller, it gains better response that way. the actuator has to be pulled up tight.
Oh me no know. I just remember another mate asking me the other day lol
Haven't changed the preload on the actuator didn't need to remove in on the install, so its as is from Stao :)
Cheers!
Just need to fix the aircon hose. Do the injectors and afm then Im done!
Just waiting on a booking time from Trent/Cat
Oh and also ordering a new 3inch 100 cell venom 5inch body cat.
Found out my old cat was 2.6inch.
And don't want to run a de-cat dont want a potential $10,000 fine :/
Picture below:
If this is a track car then I think you are worried about the wrong black hose. I would be doing something about the coolant hose going to the heater core that is only a few inches from the no.6 cylinder runner on the manifold you are running
If you run 50;50 coolant and the temps are up over 95 when running and it splits then this can happen to you too :)
End up with ethylene glycol being sprayed onto a rad hot exhaust which can lead to some unexpected, interesting problems :)
    • Sounds good.  I don't 100% understand what your getting at here. When you say, "I keep seeing YouTube videos where people have new paint and primer land on the old clearcoat that isn't even dulled down" do you mean this - there is a panel with factory paint, without any prep work, they paint the entire panel with primer, then colour then clear?  If that's what you mean, sure it will "stick" for a year, 2 years, maybe 3 years? Who knows. But at some stage it will flake off and when it does it's going to come off in huge chunks and look horrific.  Of course read your technical data sheet for your paint, but generally speaking, you can apply primer to a scuffed/prepped clear coat. Generally speaking, I wouldn't do this. I would scuff/prep the clear and then lay colour then clear. Adding the primer to these steps just adds cost and time. It will stick to the clear coat provided it has been appropriately scuffed/prepped first.  When you say, "but the new paint is landing on the old clearcoat" I am imagining someone not masking up the car and just letting overspray go wherever it wants. Surely this isn't what you mean?  So I'll assume the following scenario - there is a small scratch. The person manages to somehow fill the scratch and now has a perfectly flat surface. They then spray colour and clear over this small masked off section of the car. Is this what you mean? If this is the case, yes the new paint will eventually flake off in X number of years time.  The easy solution is to scuff/prep all of the paint that hasn't been masked off in the repair area then lay the paint.  So you want to prep the surface, lay primer, then lay filler, then lay primer, then colour, then clear?  Life seems so much simpler if you prep, fill, primer, colour then clear.  There are very few reasons to go to bare metal. Chasing rust is a good example of why you'd go to bare metal.  A simple dent, there is no way in hell I'm going to bare metal for that repair. I've got enough on my plate without creating extra work for myself lol.
    • Hi, Got the membership renewal email but haven't acted yet.  I need to change my address first. So if somebody can email me so I can change it that would be good.
    • Bit of a similar question, apprently with epoxy primer you can just sand the panel to 240 grit then apply it and put body filler on top. So does that basically mean you almost never have to go to bare metal for simple dents?
    • Good to hear. Hopefully you're happy enough not to notice when driving and just enjoy yourself.
    • I mean, most of us just love cars. Doesnt necessarily have to be a skyline.
