guys FYI the following is 400 bucks delivered:
http://www.ebay.com.au/itm/261045441228?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649#ht_1390wt_1397
that is a GTR item which will work on any 240mm push type nissan clutch, RB25/SR20 included.
the clamp load is 1100kg so 300kw shouldnt be an issue. drivability will be as close to stock as possible.
hope that helps, NPC are good but you will be stunned @ the price.
Hey Scott,
I think those are the Exedy HD (re-manufactured pink cover ones). The Exedy Sports (silver cover) are the ones you want, the pink ones are terrible, I have had one before uneven wear on the friction plate not to mention you often hear people complain about them on various forums. And pedal feel of Exedy vs. NPC, Exedy pedal is super heavy not to mention people end up breaking pivots as well.
Hey Scott,
The re mfg pink cover is made in Australia, the rest of the world gets the japanese MFG silver cover item. That clutch is coming from the UK.
You can also tell by the box where it says 'exedy racing clutch' with Daiken logos. Where as the said pink cover clutch will come with the ghey 'sports tuff' box.
Excuse my ignorance, but is clamping load all that determines if a clutch can handle a particular power level? I would have thought power delivery, torque, driving usage type etc all affects it also??
The friction material itself obviously affects the amount of torque that the clutch can transmit. If you have a higher coefficient of friction, you get more grip out of the same clamping force. The detailed design of the clutch affects the way that the raw clamping force is distributed across the plate(s), which will also affect how good the clutch is. Simply think of that as the clutch being 95% efficient, or 85% efficient, depending on how well it uses the total clamping force available.
Clutches can be (and usually are) generally "rated" at a certain power level on a given engine because the diameter is essentially fixed across most clutches for that engine and the torque/power delivery variables are almost fixed. Move the exact same clutch over to some different engine and the rating might have to be tweaked. If you take driving style into consideration, then the "power rating" of the clutch assumes a perfect driving style and you would sensibly de-rate the clutch for any non-perfect driving (whether that be the usage model or the clumsiness of the driver, etc).
Yeh start doesn't affect mph much.
Well. Guess that explains our runs at Powercruise. Either we are both hugely down on power, or our turbos are extremely laggy between gear changes.
I say laggy between gear changes.
Im pretty sure if i got a good run i would most likely do around 14.1
Am i changing gears wrong? should i be flat footing the whole way and riding the clutch in gear changes lol???
101mph? That'd have to be a HELL of a launch etc to do low 13s or 12s off that, with slicks at least. 101mph is reasonably typical for high 13s/low 14s on a clean run. What power and type of car are we talking? With reasonable spool I'd be expecting under 200kw from an R33 - if it is much over 200kw then its not a driver issue, it is something to do with how the power is delivered (which could include how much power there is).
I will take mine to the drags after i get my turbo back from Stao and retuned. See how it likes ~6000rpm clutch dumps on MT's
thats it, teach that c*nt a lesson
hopefully i can borrow a go pro and can video me trying to rip the gearstick out the back window (as said by Jez himself on a prior test drive)
    • (it is a brand new ported mellings pump) I suspect the lack of pressure is due to the leak. It was *not* that low in other logs of oil pressure in the past. It wasn't that hot either, but not far off.
    • Would a Mellings oil pump be a viable option  From my time with a LS, and talking to tuners and LS specialists, the "weak" OEM oil pump is one of the first things they recommend to swap out if I was going to give the engine any high RPM I opted for a Mellings high volume, with the high pressure springs and I never had a issue with it Cost wise they are not expensive in the scheme of things
    • Just bought a 2002 Stagea 250tRS VR-X Four AERO VQ25DET and spent the last two weekends cleaning and detailing it.. still have to do the wheels and the engine bay but the rest of it came up nice. Imported 2011 to S.A. and I'm the third owner since it was imported. I met the guy who brought it over, he went to Japan and picked out the car, bought it and ordered the wheels. He also gave me a list of stuff he did to the car with receipts. Coil overs (I have the original springs), 3" exhaust from the dump pipe back no cat, Custom dump pipe,(I have the original exhaust), Plenum spacer, 18" custom Work XSA wheels (need restoring, I've made a start..), Shift kit put through the 5 speed tiptronic auto, TV and menus/screens changed to english, Australian DTV tuner installed in rear. I've just had four new discs and new pads as well as all the fluids including the brake fluid replaced. I have all the receipts for the last 15 years and the import papers in a nice folder. Car looks great, goes like hell but fuel economy is not a thing lol.. pics next..
    • I ended up in this rut again lol, and used a shit ton of filler. One thing I can't understand is, even after using a big long block and going in long X pattern strokes, I always end up at bare metal again with no filler, and my repair started at one end of the door and now I've chased my tail to almost the other end of the door. I was thinking of hitting the panel with a hammer where it might be a high spot and making everything low then filling it, I did this on a small section on my other door by mistake and I think I fixed it lol. Is this a bad idea? The other thing is with guidecoat, whether it's the powder or spray, after I sand all the guide coat off, it doesn't reveal anything for me in terms of high spots and low spots and makes it especially hard when it's bare metal (at least in powdered form), am I doing something wrong here, or likely a high spot I keep going over and creating valleys? Lastly, stupid question but, is it possible that after sanding if I only sand over the filler area where I know to be a dent that it's impossible for me to dig into that dent? Unless there are other problems which I missed.
