I would be interested to see inside the bore, and perhaps the plugs tips if they are still there. I too noticed the dint in the backing shield, dare I say Det damage? It looks like it's been blasted by hot metal particles.
Can a turbo perform better on a dyno than on the road?Like could two turbos that makes 250rwkw with the similar power curve get totally different results on the road.
I think what's happening is we are making the power but have a lot of lag between gears. On a dyno you're loading it up in 4th,so you don't see the difference between gears, but at the strip it makes a huge difference.
Now that I have the gopro hooked up I might test this and record the time to build boost back up.
I was completely oblivious until Stao rang me about it. The plugs were fine, the motor doesnt miss a beat and I havent seen any oil being burnt.
Unless some of my valves or pistons are missing chunks and somehow continue to run, i was thinking maybe some slag or something has come away from within my exhaust manifold and caused this.
The launch control probably doesnt do the turbine any favours either. :whistling:
Wait I thought this was stock manifold, what manifold is it for slat to let go?
I ask because ive seen a known brand manifold do this to a kando recently.
I met you at a trackday a while back.
Wasnt yours the car with the bolt-ons from another car (turbo, intake manifold, injectors etc etc) as well as the ECU. But the ecu was tuned for those mods of the bolt ons in the other car and you hadnt bothered to get it tuned again to your car, you just hooked it and and went from there.?
If so then some decent DET might have been occurring methinks...
Sorry you have me confused for someone else. I have an ATR43G3, standard plenum, nismo 550's and ViPec ECU.
I don't know about 115mph, but 106mph is way low for ~250wkw. Quite an odd pattern forming!
Thats stagea kw for mph..
I'm a bit lost, but most of the cars that have run the drags so far , are the ones that had problems on the dyno
anyway i thought, so i don't see a clear picture yet, Stao should go
cheers
darren
Edited by jet_r31
Was going to say that - my Prelude needed around 130kw to pull 96-98mph trap speeds and weighed ~1330kg as raced, must be an ultra low reading dyno to do 97+ with a "130kw" 300ZX.
I'd hope for over 98mph with 200kw in an R33 too, though.
That's what the dyno read and that's what i'm going off. I'd rather have the low reading dyno number and a good trap speed than the other way around.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
