$800 including oil line. Depending on when can get it tuned, will be looking towards a weekish mark.
Also this high flow is made to aim 400rwkws mark, So it might not be very responsive.
Stao. Would you have a run of the new high flow against the ss1pu turbo i've got? Appears all the SS turbos runs the same compressor wheel, please share some light of the difference between the three.
SS1PU runs a turbine sized similarly to a GT28, GT28 spec rear housing and T04B front
SS2 runs a turbine sized similarly to a GT30, 5 bolt T3 rear and T04S front
SS2.5 Highflow runs a completely custom spec turbine (will leave details to Stao), stock 2IU housings
Some further updates. Since the majority of market is pushing for a cheap and cheaper option, I've managed to find and import some 21U copied turbine housings from China. Crazily machinery costs is only 1/30th of what my accumulation is in Australia.
So here it is, a Cheap turbocharger that produces decent power and response. The ATR43G3.5. Since 1/3 of the turbo and machinery work is done overseas. I can manage to squeeze the price down to only $850 including braided oil feeding line.
Dyno trailed today with very successful outcomes. It managed to archive 355rwkws, maxing out at 22psi. Far as pricing concern, this makes the lowest $/KW ratio turbocharger with added benefit of Rb2x bolton.
It is pretty aggressive on road. expecting to see some where around the 320rwkws used as a internally gated turbo on pump 98. I've already mentioned the limit of stock exhaust manifold, so its up to the end user to sort out their own manifold and other supporting mods.
Stao, all you need to do now is take that turbo to the drags.
Get us a trap speed to verify the power and watch them fly out the door.
If the trap speed is indicative of the power I think you will be selling these faster than you can produce them.
Its using a 2IU exhaust housing rather than a .82 type A/B
The turbine wheel has been re-done to better match the tight 2IU housing.
It seems to have been developed to be 100% bolt-on ready and can be further developed down the track to have monster high mount potential.
The G3 and SS2 do produce noticeably strong mid to top range power with better transition response since they are built with a small turbine and the advantage of a reasonably large housing.
This turbocharger is good for a budget built. Like all other ATR, with very high external gate high mount potentials.
I will be working on the SL2 10cm based turbochargers next week. releasing 2 new models.
Hey all, after having a chat to Stao today I am tossing up between the SS2 or the new 3.5G
Has anyone got a dyno graph of SS2 on 98 internally gated on standard manifold?
Thanks
The SS2 for RB25det is only in T3 .82 FNT rear with RB's IWG assembly. The latest one is slightly more responsive:
http://www.skylinesaustralia.com/forums/topic/261613-hypergear-hiflow-service-continued/page-360
and required lot less duty on the ebc. So it will work better with factory manifold internally gated.
This is video track footage from John. Running a standard high flow from 2 years ago. It should be the last run of it as its getting a update to the latest SS2.5 profile.
car is currently on 260rwkws.
had a retune @ garage 101 the other day
as it stands it has
3" TBE
ATR43 with .63 trim - 4" inlet pipe and pod
hybrid inlet manifold and low mount exhaust manifold
850cc injectors
walbro
new clutch
think thats it
366whp @ 17psi
FYI
I am going to racewars (perth) and will be racing.
I guess ill be the first Hypergear Turbo to do a 1000 meter sprint?
Will be happening this weekend, hope to get as close to 300 as possible :):)
Will post my results up when im done :P
FYI
My guess is about 240-250kph.
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
