$800 including oil line. Depending on when can get it tuned, will be looking towards a weekish mark.
Also this high flow is made to aim 400rwkws mark, So it might not be very responsive.
Stao. Would you have a run of the new high flow against the ss1pu turbo i've got? Appears all the SS turbos runs the same compressor wheel, please share some light of the difference between the three.
SS1PU runs a turbine sized similarly to a GT28, GT28 spec rear housing and T04B front
SS2 runs a turbine sized similarly to a GT30, 5 bolt T3 rear and T04S front
SS2.5 Highflow runs a completely custom spec turbine (will leave details to Stao), stock 2IU housings
Some further updates. Since the majority of market is pushing for a cheap and cheaper option, I've managed to find and import some 21U copied turbine housings from China. Crazily machinery costs is only 1/30th of what my accumulation is in Australia.
So here it is, a Cheap turbocharger that produces decent power and response. The ATR43G3.5. Since 1/3 of the turbo and machinery work is done overseas. I can manage to squeeze the price down to only $850 including braided oil feeding line.
Dyno trailed today with very successful outcomes. It managed to archive 355rwkws, maxing out at 22psi. Far as pricing concern, this makes the lowest $/KW ratio turbocharger with added benefit of Rb2x bolton.
It is pretty aggressive on road. expecting to see some where around the 320rwkws used as a internally gated turbo on pump 98. I've already mentioned the limit of stock exhaust manifold, so its up to the end user to sort out their own manifold and other supporting mods.
Stao, all you need to do now is take that turbo to the drags.
Get us a trap speed to verify the power and watch them fly out the door.
If the trap speed is indicative of the power I think you will be selling these faster than you can produce them.
Its using a 2IU exhaust housing rather than a .82 type A/B
The turbine wheel has been re-done to better match the tight 2IU housing.
It seems to have been developed to be 100% bolt-on ready and can be further developed down the track to have monster high mount potential.
The G3 and SS2 do produce noticeably strong mid to top range power with better transition response since they are built with a small turbine and the advantage of a reasonably large housing.
This turbocharger is good for a budget built. Like all other ATR, with very high external gate high mount potentials.
I will be working on the SL2 10cm based turbochargers next week. releasing 2 new models.
Hey all, after having a chat to Stao today I am tossing up between the SS2 or the new 3.5G
Has anyone got a dyno graph of SS2 on 98 internally gated on standard manifold?
Thanks
The SS2 for RB25det is only in T3 .82 FNT rear with RB's IWG assembly. The latest one is slightly more responsive:
http://www.skylinesaustralia.com/forums/topic/261613-hypergear-hiflow-service-continued/page-360
and required lot less duty on the ebc. So it will work better with factory manifold internally gated.
This is video track footage from John. Running a standard high flow from 2 years ago. It should be the last run of it as its getting a update to the latest SS2.5 profile.
car is currently on 260rwkws.
had a retune @ garage 101 the other day
as it stands it has
3" TBE
ATR43 with .63 trim - 4" inlet pipe and pod
hybrid inlet manifold and low mount exhaust manifold
850cc injectors
walbro
new clutch
think thats it
366whp @ 17psi
FYI
I am going to racewars (perth) and will be racing.
I guess ill be the first Hypergear Turbo to do a 1000 meter sprint?
Will be happening this weekend, hope to get as close to 300 as possible :):)
Will post my results up when im done :P
FYI
My guess is about 240-250kph.
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
    • I used to do that (sills with rubber jack block).. ... then I got side skirts, and there's no way for the jack to actually work there, the jack pad itself on the jack is too big. Is the answer to use a... smaller (?) jack? Hmmm.
    • I have too much trauma from every skyline I've ever seen having crushed jack points/pinch welds lol.    Yep, works 100%, it's what I use when I'm using the quick jack. Don't know why I can't also bring myself to do the same thing when I'm using a jack. I blame the skyline PTSD.
