good work guys. should make a nice improvement with a functional gearbox and grippier tyres. i thought RSR's were quite grippy but with 350rwkw maybe they dont stand a chance, especially with axle tramp going on.
vids next time? :)
Nice work on the strip :-) glad its now proven that the turbos can trap the speed.
now its time for others to revisit their setups and their tuners.
Indeed, those trap speeds are much more like what one would expect from those power levels... for the sake of interest, what kind of blow of valve is this car running?
Well done stao and status - must've been interesting having it try to swap ends in 3rd or 4th on the strip! :P
Can't wait to get this new clutch in and get back to the strip.
What tyres are you going to run next? Some semis?
He's getting axle tramp as said which wouldn't be helping things.
Stao as reference if you aren't running pineapples already you should get onto it asap.
My S14 has pineapples and does not tramp at all, while friends who don't have the pineapples tramp like mofo's.
Yep, i agree... I had bad tramp and put the collers (dunno how to spell lol) and it made a HUGE difference....
Tramp is less about pineapples and subframe location issues than it is about damping. I agree, locking the subframe up with better/newer bushes and/or pineapples is a big help and probably a necessity, but I would always look to the rear damper settings/health as my main concern when trying to fix tramp.
GtScott: Would great if you can pass on a link to those pineapples. I will have a look into them.
Been recommended to Mickey Thomson 16inchs drag tyres. Will need to source that and a set of factory rear rims.
I took few video footages in bystander area. Will upload shortly.
Yep 11's would be my guess..... And yes locking the subframe made a huge difference on my car but doesnt mean it will on all cars :)
I'm thinking what happens if run a 1.06 turbine end on the G3. it should take away all the zappiness down low causing wheel spin while kicking in mid top range while the car's rolling at much higher speed.
Noob question. Quarter Time stands for taken completing the run. Does the car with higher mileage stands for a faster car after the completion of the track? assume if the run way is 1 full mile instead of quarter mile.
    • Had I known the diff between R32 and R33 suspension I would have R33 suspension. That ship has sailed so I'm doing my best to replicate a drop spindle without spending $4k on a Billet one.
    • OEM suspension starts to bind as soon as the car gets away from stock height. I locked in the caster and camber before cutting off the kingpin. I then let the upright down in a natural (unbound) state before re-attaching it. Now it moves freely in bump and droop relative to the new ride height. My plan is to add GKTech arms before the car is finished so I can dial camber and caster further. It will be fine. This isn't rocket science. Caster looks good, camber is good, upper arm doesn't cause crazy gain and it is now closer to the stock angle and bump steer checks out. Send it.
    • Pay careful attention to the kinematics of that upper arm. The bloody things don't work properly even on a normal stock height R32. Nissan really screwed the pooch on that one. The fixes have included changing the hole locations on the bracket to change the angle of the inner pivot (which was fairly successful but usually makes it impossible to install or remove the arm without unbolting the bracket from the tower, which sucks) and various swivelling upper arm designs. ALL the swivelling upper arm designs that look like a capital I (with serifs) suck. All of them. Some of them are in fact terribly unsafe. Even the best one of them (the old UAS design) shat itself in short order on my car. The only upper arm that works as advertised and is pretty safe is the GKTech one. But it is high maintenance on a street car. I'm guessing that a 600HP car as (stupidly, IMO) low as you are going is not going to be a regular driver. So the maintenance issues on suspension parts are probably not going to be a problem. But you really must make sure that however your fairly drastically modded suspension ends up, that the upper arms swing through an arc that wants to keep the inner and outer bolts parallel. If the outer end travels through an arc that makes that end's bolt want to skew away from parallel with the inner bolt, you will build up enormous binding and compressing forces in the bushes, chew them out and hate life. The suspension compliance can actually be dominated by the bush binding, not the spring rate! It may be the case that even something like the GKTech arm won't work if your suspension kinematics become too weird, courtesy of all the cut and shut going on. Although you at least say there's no binding now, so maybe you're OK. Seeing as you're in the build phase, you could consider using R33/4 type upper arms (either that actual arm, OEM or aftermarket) or any similar wishbone designed to suit your available space, so alleviate the silliness of the R32 design. Then you can locate your inner pivots to provide the correct kinematics (camber gain on compression, etc).
    • The frontend wouldn't go low enough because the coilover was max low and the upper control arm would collapse into itself and potentially bottom out in the strut tower. I made a brace and cut off the kingpin and then moved the upright down 1.25" and welded. i still have to finish but this gives an idea. Now I can have a normal 3.25" of shock travel and things aren't binding. I'm also dropping the lower arm and tie rod 1.25".
    • Motor and body mockup. Wheel fitment and ride height not set. Last pic shows front ride height after modifying the front uprights to make a 1.25" drop spindle.
