Needs 'Hypergear ALFA series' cnc'd into the front housing, on the built plate area. :)
Can you do the above to an M35 turbo for me Tao? Is that 320kw on e85 or 98?
If it can get up to about 340rwkws then that would be sweet. Means about 300rwkws on pump 98.
I drove it on low gears light throttle around the block, it felt like a stock turbo more then any thing else. Be interested to see what the dyno says in few weeks time. If works well this would be an excellent turbo for Rb20det and SR20det engines.
Advanced Lag Fighting Abilities?
:whistling:
Yes you are right. :D Its actually from Alfa Romeo . Alpha sounds too american. Lets stick with American wording for now.
To produce this it has to out perform the SS2 Alpha version which I think that is extremely good. Will post result after Trents get back from UK.
Just clear up some confusion as proportion of people don't understand how the alpha turbocharger is any different to traditional turbochargers.
If a traditional turbocharger is built for 600HP it will be, drive and act like a 600HP turbocharger in all rev ranges.
At same HP, the Alpha turbocharges, drives as a 400HP turbo from 0~4000RPMs, 500HP turbo from 4000~5000RPM, 600HP turbo from 5000~7000RPM. So it will always feels like a baby turbo to drive while produces decent top end.
At any given freedom of variable nozzles angle, the turbocharger is only capable of producing a proportion of it full HP capacity. For example if nozzles are fixed at 10 degrees a 600HP turbocharger will only produce 300HP maximum, 30 degrees at 450HP, 45 degrees at 500HP, and 50 degrees at 600HP.
When controlled by an actuator with preset actuation levels, on given boost, this turbocharger will expand it self from a 300HP turbo to a 600HP turbo as engine reves out, then contract to a 300HP turbocharger off acceleration. It repeats this process throughout the whole driving course.
Most of our budget went into developing and research for newer innovations. This is a giant step forward for modern performance turbochargers.
Updates of some unusual turbocharger. The Schwitzer turbo out of a early model Toyota land cruiser diesel.
Turning that into our Billet TD05H18.5G is a total workout in ingenuity. Here it is:
Expected to gain about 15% more torque without adding much lag.
An old Schwitzer hey. I rebuilt an excavator engine with a Schwitzer turbo on it a few years ago. That turbo was a bit bigger however, about 40kg
Just remember how funny the name was when you say it with some sort of European accent :P
Not all... :ph34r:
No, Stao was right when he said "all". A 600HP turbo will feel like crap at 2500rpm. That's what he meant. His 600HP alpha turbo will feel like a 400HP turbo at 2500rpm, but will be capable of also doing 600HP.
Mine has plenty down low! Of course you can feel its not a stock turbo and you know its big but its not a lag monster by any means! The dyno sheet doesnt do it justice... I just think that general statement is wrong!
No......yours does feel like a 600HP turbo down low. Just because it is Stao's special recipe and is actually quite good down low doesn't mean it can't be better. If you add his Extra Special Recipe © to it, it will be even more good down low. That's what he was saying.
I mean, lets' be fair......I'm not rubbishing the turbo you have, because I know full well that it is a good thing. The point is that it must spool a bit slower than the stocker, and the stocker is a 400HP turbo. An old, crappy 400HP turbo, but let's ignore that aspect of it. Stao's statement was,"Add VNT to your big turbo, get stock turbo response at low rpm, add big grin to face."
Edited by GTSBoy
Oh, didnt realise you had driven my car :) My bad...
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
    • That still isn't a lot to go on. I don't have a Y50 Fuga Head Unit wiring diagram. I can say that a lot of nissans of that age shared head unit plugs, so if you are in Australia something like this would probably help: https://aerpro.com/app091# You plug that into the car loom, then either plug the head unit ISO into that (if it has ISO), or you buy and ISO adapter harness that you wire in. Bit of stuffing around, but once you have ISO its easy to change things in future.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
