I don't think that would be a problem. I can upgrade it to the latest profile, which is targeted at boost dropping issue with internal gate. PM if interested to go ahead.
If it hit a wall at 250 and pinged then I don't think holding 20psi through the whole rev range is going to really help anything. I'm going to keep searching and try find the issue
Unless a leaking PCV could be causing a boost leak and pushing oil out the failed cam covers ;)
Buy a new PCV to be sure, to be sure.
Ooh ooh anyone know the part number for the PCV hose on a 34? Completely off topic i know :P
LOL What a lazy prick :P
Nissan 11810-AA500 - that's the valve. Dunno if you actually mean the HOSE.
:laugh: yeah i know!
And YES i actually want the hose too!
lol that I cannot help with. I would have thought any old hose will do?
Useless :P
Maybe, i was just being lazy!
Cams are in. They are Tomei drop in 264 / 8.9mm lift. Now working with SS2 Alpha, Dyno tomorrow.
Driving them back from mechanics, the exhaust has a slightly different note. Haven't give to them yet, hopefully hitting 400rwkws+ while still making 20psi by 3500rpms.
Don't know. I was at TAB having dinner with bunch of Oddies while the Mechanic doing his job. It was done at Springymotors south east of Melbourne.
Hate people whom junk yard shopping that buys 2nd hand junk that don't work, that is been cheap-skating on basic mods as injectors, afm and ecu, It puts Trents in to a mood and that held every one else whom's waiting to get their car tuned.
Unfortunately I'm one of the two person whom's asked to go home and come back next friday. Leaves me with some extra time building SS4 Alpha turbocharger.
Damn Stao, it's gotta be 3 hours back to your place in this traffic. Was a shame, I wanted to see what it could do.
Wasn't it you last week with the cheapskate injectors? :P
They are 650cc Bosch injectors and they are working properly. Its more due to the one ended fuel rail in the KIA. the other once cam out of them are Power enterprise 700ccs, way too big for idle on that car.
The VNT setup on the SS1PU is chocking the Rb25det down low, not sure if its ok for the SR20det as engine capacity is smaller. I'm reducing the compressor end down to 69mm from 74. which should match the turbine flow while picking up better response. My last tune for this month would be next friday and that will be the SS-4 VNT turbocharger. The new SS1PU will have to be trailed after Trent gets back from China.
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
