Speaking of injectors don't buy deatschwerks , they pop and misfire like crazy at low duty cycles, great power with no det, decent economy (14-16L/100km with 260kw) but yeah pop pop pop at idle and cruise.
Did you mean decent economy as in good economy?
I was getting 14L/100km or less around with Nismo 555's and about the same power level and the thing was running rich. I had a massive buildup of carbon in my dump pipe when I pulled it off and the thing used to shoot flames all that time
The deatschwerks were one of my backup options if I ever needed to upgrade from my new 740's so interested to hear some more feedback.
you got a plenum already so get some top feeds Cal..a full set will be much less than sidefeeds so spend 100$ on a rail...or you can just use a NEO rail which ahs the reg built in....@ 300kws on a highway run I get as good as 10L/100km on ethanol with 750cc xspurts... ;)...
cold starts still use alot of juice though and kill around town economy but thats ethanol..still gets around 15L/100 though...my petrol tune uses much less
Which Deatschwerks are you using, the older high flows or the current generation ones ( like these http://www.deatschwerks.com/products/fuel-injectors/sport-compact/nissan/skyline/neo-rb25det/1998-02-neo-rb25det )? I have a set of 800cc high flows with SS2 and a similar power level. The only popping I'm getting is occasionally when lifting off rapidly on high boost. They seem to idle fine.
The new generation ones, I got the R33 replacements, what ECU are you using? I'm using nistune however Jaustech here in Adelaide are also having the same problems as me on another set of 740cc's running E85.
Edited by Rolls
I looked at going top feed. The injectors are alot cheaper but the initial setup costs more then a new set of sidefeeds. When I got screwed over with being Nismo 740's off someone on here, So I cut my loses and bought some new 740's
Maybe next time lol but I'll probably go side feed again :P
I managed 9.9L/100km with my car once. But only once lol. Was a big achievment
not just cheaper ..better...
Sorry I'm currently in China working into the KIA project as well as some of VW turbo systems. I will be back in two weeks.
Workshop is running as usual, if you can't find me over the phone please email or PM your inquiry though I usually reply within 24 hours. Thanks.
The 1200cc injectors worked fine on my R33 so if any one's looking for a set of high capacity cheap dropins, they are fine.
Edited by hyper-gear
For anyone interested these are my recent results of before and after on my rb25 with a hypergear tr43i. Red line was previous results and blue line is new, changes were brae hi mount manifold , convert turbo to external gate with hypergears 50mm wastegate.
Car made more power, more torque and better response. Also feedback for the fiveomotorsport 1000cc injectors they were perfect so another positive result for them.
Thats a neat gain from the manifold and gate.
Is the TR43i an older HG turbo?
Yeah its hes really early model turbos from about 4 years ago before the atr series.
Dyno reading from another customer's R33 Rb25det GTST, Appears to be using the current profiled high flowed 21U Stock turbocharger. 271rwkws on pump 98 fuel and supporting mods.
I think the RPM scale is wrong:
Yeah maybe. They couldnt get an RPM signal from my car for some reason when they dynoed it (ages ago) so maybe it just defaulted to roller speed. Funny that it looks exactly half what the engine speed should be though
makes it look impressive anyway, full boost at just over 2000rpm lol
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
    • The annoying part about neglect, is when you start to replace one thing, and find ten more broken things. Ham fisted monkey repairs you normally only find out about when trying to do something unrelated! Ha ha   Neglect you can kind of anticipate the huge costs to fix it all. Ham fistedness is normally a shock the first time your work on a new old car, as everything "looked" good before.
    • For DBA, check out their guide table here. https://dba.com.au/wp-content/uploads/2023/01/Direct_Replacement-Guide-2021.2.pdf   Additionally they have some other guides and info on how to make sure you choose the right pad.
