It goes to the back of the intake manifold. But it's a push-on fitting on the manifold so I just used standard rubber hose to behind the head, then an AN-AN adapter with a push in fitting on one side and braided line on the other. Makes it a bit more expensive but it's all straight fittings so it's not too bad. I wouldn't do it any other way, hard lines and banjo fittings are the worst.
So with a high flow 21U I wouldn't have to bend the stock water lines like I did when I fitted the SS1PU?
Just trying to work out my options for my R34
I have an SS1PU to transplant into the r34 but I don't want to go through the issues I had with the oil drain and the water lines.
Using R34 OP6 rear housing for high flowing can probably archeive towards 280rwkws . How ever not sure what the lag would be like.
I guess I'll try my luck again and if I can't work it out then ill pay someone to do it.
R33 gtst - mod list
Hybrid fmic
Hks super dragger 3.5"
Splitfires
Nismo 740cc inj
Stock cat (made into decat)
3" stainless intake
Z32 AFM
3A racing pod filter
Apexi evc
Plugs are bcpr6es gapped at 0.8
Tune in progess 2 hrs to go.
  • Like 1
Winner!!
Thats a good graph. Almost half your RPM range is on power, and peak torque would be pre 4k :)
Anyone building a sub 300kw RB25 would be silly to buy anything else.
My mates, mate(lol, i know), bought one of these new hi-flows of stao a few weeks ago for his manual rs4's stagea
apparently he rates it highly already with just a decent nistune base map in it on low boost so far, think they are doing
ponnies in it next and then getting tune sorted
My mate drove it and raved about its response , Bang for buck it sounds like a real winner...
cheers
darren
+1 for hypergear. My turbo was apparently some odd bod creation with an R32 rear and R34 front. Had it hi-flowed with 12 psi actuator, gained up to 60 rwkw and 100 nm, with hardly any "real" change in response (stock made 10psi at 2800 rpm, now just under 16 psi at 3500rpm)
Sheets here:
http://www.skylinesaustralia.com/forums/topic/249186-nat-power-results-na-t-turbo-conversions-only/?view=findpost&p=7103500
    • all brand new unit from Tomei, fluid, bearings, etc. Tomei said they call it a 1.5 lsd because its 100 percent lock up under acceleration and 50 percent under deacceleration.  as I mentioned I used their fluid, install and their break-in procedure, (alot of figure 8's) but even when driving straight, or even slowly backing out of garage for first time, (at 2 mph) then driving to and from figure 8 parking lot, each tire in the rear would sporadically grab, skip, bounce, shutter and skip, shutter back a force I could feel causing clutch to slip then grab, at any speed. shaking entire car. I removed unit, since I put stock back in and all is fine, via process of elimination, its something with the lsd unit itself. I wasn't going to beat up the entire car more or change anything else for no reason as I had a feeling something in the lsd itself was wrong as everything was fine before this alone was installed and I rechecked over everything else after first time backing out I suspected an issue. I'll probably sadly already need new tires now just from trying to drive it 5 miles and performing the figure 8 break in. but if someone has any ideas I'm all ears
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
