The Nissan IWG assembly can be unbolted. Can use a Vband assembly as above or my personal preference bolting up a flange plate with a 3inch pipe welded into the flange.
like below:
http://www.hypergearturbos.com/images/atr45rear.jpg
The key to success is buy and work with quality. It took a while, I've managed to pickup a worked S14.5 with engine fully built by Forced motor works and tuned by Chequered Tuning that is very properly done with lots of goodies.
Gizzmo boost controller (tuned for 21psi running on 19)
Autometer wide band AFM
Boost gauge
7000km rebuilt engine with 260rwkws (built by forced motorworx)
BC 260 cams
Drift Exhaust manifold (low mount)
RAS (rocker arm stoppers)
CP pistons
BC rods
New turbo (Garrett 30-71)
700cc Nismo injectors
Nistune chip (tuned by chequred tuning) 260rwkws (with dyno sheet)
Custom air box
PWR radiator and intercooler (intercooler is inside engine bay so no chassis cutting)
Custom aluminum radiator overflow
Cusco front strut brace
HKS coil overs all round
Greddy oil sump
Spit fire coil packs
New varex exhaust system
100cell race cat
Z32 Air Flow Meter
In which will it be used in developing T2x based turbochargers for SR20det motors.
With VCT been cancelled. The GT3071R turbocharger in a .64 rear housing is horribly laggy for this SR20det. After driving it 63kms back, I have to admit:
RBs are Awesome.
Lets see if I can manage to same power with heaps better response.
Good score Stao! Sounds like a fantastic platform.
Its horribly laggy. I have a dyno reading from Trent before went to see that car. It makes full boost at 4600RPMs. enough revs for me to pump 490rwkws out of the R33. Since its been sitting in garage for a long time I think its got some fuel pump issues cutting off randomly on boost . Its going to be taken back to Forced Motorworx for a full check up before pumping through 24psi.
Lol.
My stock SR20 with a GTX3071 in 0.82 makes boost before that. Something wrong in the setup.
Btw, saw a 180sx running a gt2871 trap 128mph... Full interior.
But yeah, super excited to see SR development. :)
If I can get VCT enabled that should make a huge amount of difference. Its currently on cam gears. need to get this fuel problem fixed first. So will come to that abit later. any one knows SR inside out in Melbourne whom's interested to do some work?
If I was in Melbourne I could have helped you out
Know sr and s chassis fairly well
You will need a bigger walbro pump if you going to run e85 anyway and larger injectors
Go walbro e85 pump 460lph rewired and just get those 1200cc side feed injectors you got for the skyline work ok on s14/15
Get rid of that stainless manifold and put the std cast one back on as that will be where 500rpm lag will be and it's normal for the cropped t2 version gt3071r to come on boost at 4-4200rpm depending on boost
Get rid of those adjustible cam gears and put VCt gear back on will drive a lot better
Will my turbo be finished before the end of the year ? If not I'll just wait till January cause there might be delays in post anyway due to Christmas and new year thanks
whats the dags?, sounds like something sheep get...lol
cheers
darren
FKN LOL, missed that. What a dag!
lol yeah more that I want to compare mine to this 260kw lag monster. Not that 117mph is crazy or anything haha
I want to head out to wsid again to test out my atr28g2 next wed before I take it off for the ss1.5
Hopefully should trap 123mph+ as last Time I only got 2 runs and my cooler hose kept blowing but managed 1 clean run on low boost 20psi but still got a 12.4 @ 120mph
Now I got the 20psi actuator and before my twin tip varex had a resonator in the tips which look to neck down to 2inch which I removed and the centre hotdog
Should go good hopefully I can get closer to the 11s
LOL @ SR circle jerk. I'M IN!!!
Haha, last outing I destroyed my clutch and am since still waiting. Japanese tracking either says its on the ship or in the ocean somewhere, I guess we will find out in another 7 or so weeks lol.
Yeah, should be able to do that. I have a track day this Thursday, so if nothing blows up, I'll be in.
Car was originally tuned at Unigroup (290 as well- their dynos are identical I've found from personal experience), however I use DVS Jez, and has been to him quite a bit. Stock S14 motor, incld headgasket. GTX3071R 0.82 housing, 6Boost, 44mm Tial. 289kw@18psi on 98.
Lets go and see what they do, if I make it through the gearbox! :P
Also, can i get a rollcall on who is using what dump pipes with their turbos. I was using a (very old) JJR Bellmouth with an internal gate SS2 and the wastgate flap was fouling on the dump.
Thinking about buying the same thing again, but want to see what others are running, as smoe form of boost control would be great :)
:woot: waoo 435rwkws with 200rwkws by 4000RPMs out of a Rb25det. Pretty crazy if you guys high flow a turbo to do this I high mount it.
i have the same turbo from kinugawa GT3570 / T04 hybrid
full boost at 3800 rpm with walbro 460lph pump and 1200cc injectors
this shit is insane at 28 psi
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
