I test fitted my Kando/Hypergear td06 last night.
The fly cuts on the turbine housing aren't wide enough, so the nuts foul when trying to tighten the turbo to the manifold
Are you using 17mm nuts? Never had an issue with 14mm nuts, I just fitted one the other day.
You could just run thick washers under the nuts to clear the flycut...
  • Like 1
I have 3/8 UNF studs in the manifold, so the nuts are 5/8" (15.87mm) across the flats.
Also had to enlarge the holes a little...looks like it was designed around pissy 8mm studs
10mm might have just gone through, but after measuring it, the hole centres aren't square on both the turbo and manifold...by maybe 0.5mm...but enough that it required some massaging...and still needs a little more.
Going to enlarge the holes to 12mm and figure out a way to make the nuts work...cant even fit washers on there
Does the housing look like the one above?
Sounds like the flange on the manifold is out. What is it? And who the hell uses imperial crap on a Jap car... :P
Add in another update. This is our latest TD06SL2 based turbocharger, the SLSS-2 in 10cm turbine.
This particular one has the latest low friction trust setup, with slightly larger compressor inducer and slightly more aggressive compressor blade profile. It should be maxing out around 390rwkws mark working with a RB25det engine on E85.
It is made to produce more power, with better response and much better reliability to some of the T67 copies
Will update results shortly.
How much for this turbo? It's almost time for me to buy one
  • Like 1
Yes it is lol
The cut on the turbine housing is made for 14mm nuts.
Cheers. Will grab some 9/16 od ones and modify some washers.
Will be all good :)
Very happy with it for the price
Yes it is lol
Awesome! Getting so keen. Now I just have to find someone who will fly to darwin and tune my car for me :(
What is the inducer/exducer size of the compressor? I am about to buy a new manifold so no longer restricted by Trust 3 bolt flanges on my TD based turbos
I'm interested to know how these compare to GT3076Rs and if BB centres are an option . I still think the gap is a bit wide between GTX3067R and GTX3071R and while the HTAs look good local service isn't .
Tao is that comp housing a 0.70 AR T04B or T04S sized one ?
Also how do those TD06SL2 turbines compare to GT30s in your opinion ?
Cheers A .
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
