Do you ever pass 98RON through the tank? it's good to run 98RON every 10 tanks of E85 or so.
No-one told me this, and now I have gone and ruined my car... 5 years straight now. :/
and how do you go about doing that on an e85 tune?!!?!
I'm basing this on the assumption he has 2x tunes (which he might not).
Says who?
Five O Motorsports themselves and various other US based forums.
LOL... man you guys are digressing! I was saying to pass 98RON through the car every so often to keep the injectors happy.
Remember that these crappy highflow injectors are modified old tech sidefeeds that were designed in an era where high alcohol content fuels were nothing but a dream.
  • Like 1
lol.... yes I am aware of that, but for some we just don't pour all our money into our cars and do what we can
But what has it cost you? In wasted time and hassle?
yeah and loads of swearing - if I "had" a NEO motor I would have just drop in modern top feeds and would have called it a day.
Dude I've got the same injectors as you haha
I heard good things from 2 people and thought they'd be sweet..... nahh
Yeah I wish I had one too. I swapped out a dead R33 motor for another 33 25 that I have now.
Didn't realise the huge benefits of running the R34 motor at the time, should have done that instead
higher lift stock cams, drop in top feeds, beefier factory bottom end.. drool
Edited by Blackkers
Drops a 34 Neo in because changing the fuel rail is just all too hard. :P
Yeah just read up on that if running e85 constantly injector tips tend to gum up and even gm commodore flex cars in the states got told to run a tank of pump 98 clears up the gum
I'm on single nistune map so e85 constantly but am going to just run a e85 fuels system cleaner now on with every oil change
Edited by hy_rpm
Yeah just read up on that if running e85 constantly injector tips tend to gum up and even commodore flex cars in the states got told to run a tank of pump 98 clears up the gum
If you change fuel filters often enough shouldn't have any problems, 3 years so far for me full time e85 and everything is clean fuel filters, injectors.
I agree, mine has never been apart since I shoved the 1000's in there 5 years ago. I would imagine the tips may have some black gunk around them, but it hasn't blocked the internal injector filter, and the 40 micron stainless filters obviously let it through without gumming up. I do run teflon fuel lines though, and I am a little worried the black gunk is from the stock rubber lines.
There are two choices, change your paper filter more often, or change to a slightly more coarse stainless 30-40 micron and hopefully forget about it.
Another thing, don't use the little filter in the top that fits into the adapters, unless you want to replace them regularly. They clog up with that black gunk quickly as the surface area is minimal. I have seen it a few times now.
forums.nasioc.com/forums/showthread.php?p=37242444
Post 42
Thanks for the tip. That is pretty crazy, I thought E85 should be cleaning the injectors since it made every thing else internally pretty clean. my daily driver KIA is on E85 all times and done 23,000KMs with it so far. I will pull it out for a check up this weekend.
Yeah worth the check but even injector cleaner isn't the best solution
Running a tank of normal unleaded dissolves this gunk and mainly affects city driven cars stop and go
But if you mainly do highway kms not as bad
Might just add 10-15l pump 98 to a tank of e85 at each oil change might run very rich but dissolve this goo
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
