Do you ever pass 98RON through the tank? it's good to run 98RON every 10 tanks of E85 or so.
No-one told me this, and now I have gone and ruined my car... 5 years straight now. :/
and how do you go about doing that on an e85 tune?!!?!
I'm basing this on the assumption he has 2x tunes (which he might not).
Says who?
Five O Motorsports themselves and various other US based forums.
LOL... man you guys are digressing! I was saying to pass 98RON through the car every so often to keep the injectors happy.
Remember that these crappy highflow injectors are modified old tech sidefeeds that were designed in an era where high alcohol content fuels were nothing but a dream.
  • Like 1
lol.... yes I am aware of that, but for some we just don't pour all our money into our cars and do what we can
But what has it cost you? In wasted time and hassle?
yeah and loads of swearing - if I "had" a NEO motor I would have just drop in modern top feeds and would have called it a day.
Dude I've got the same injectors as you haha
I heard good things from 2 people and thought they'd be sweet..... nahh
Yeah I wish I had one too. I swapped out a dead R33 motor for another 33 25 that I have now.
Didn't realise the huge benefits of running the R34 motor at the time, should have done that instead
higher lift stock cams, drop in top feeds, beefier factory bottom end.. drool
Edited by Blackkers
Drops a 34 Neo in because changing the fuel rail is just all too hard. :P
Yeah just read up on that if running e85 constantly injector tips tend to gum up and even gm commodore flex cars in the states got told to run a tank of pump 98 clears up the gum
I'm on single nistune map so e85 constantly but am going to just run a e85 fuels system cleaner now on with every oil change
Edited by hy_rpm
Yeah just read up on that if running e85 constantly injector tips tend to gum up and even commodore flex cars in the states got told to run a tank of pump 98 clears up the gum
If you change fuel filters often enough shouldn't have any problems, 3 years so far for me full time e85 and everything is clean fuel filters, injectors.
I agree, mine has never been apart since I shoved the 1000's in there 5 years ago. I would imagine the tips may have some black gunk around them, but it hasn't blocked the internal injector filter, and the 40 micron stainless filters obviously let it through without gumming up. I do run teflon fuel lines though, and I am a little worried the black gunk is from the stock rubber lines.
There are two choices, change your paper filter more often, or change to a slightly more coarse stainless 30-40 micron and hopefully forget about it.
Another thing, don't use the little filter in the top that fits into the adapters, unless you want to replace them regularly. They clog up with that black gunk quickly as the surface area is minimal. I have seen it a few times now.
forums.nasioc.com/forums/showthread.php?p=37242444
Post 42
Thanks for the tip. That is pretty crazy, I thought E85 should be cleaning the injectors since it made every thing else internally pretty clean. my daily driver KIA is on E85 all times and done 23,000KMs with it so far. I will pull it out for a check up this weekend.
Yeah worth the check but even injector cleaner isn't the best solution
Running a tank of normal unleaded dissolves this gunk and mainly affects city driven cars stop and go
But if you mainly do highway kms not as bad
Might just add 10-15l pump 98 to a tank of e85 at each oil change might run very rich but dissolve this goo
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
