Hopefully this time the highflow lives up to it's expectations as I don't really want to pay more money to be disapointed again. Stao I will send you an email so this can be arranged in the new year :)
I can guarantee you won't be disappointed. Can't be bothered scrolling back to find out, but please make sure you have a tuneable ECU also.
  • Like 1
For 260rwkws, sell your OP6 and buy and send in a blown R33 turbo. Once that is high flowed, it will be making around 260rwkws with factory responds.
Got the GTR pulling 404akws today using a high flowed blown kando T67 (from Peter). And did back to back test with few different coolers, will upload results shortly.
  • Like 1
Wouldn't the r34 turbo be better for highflowing or does the lager rear create a lot of lag? My car has the below mods so the only piece to the puzzle missing is the turbo.
Apexi Pod
Nistune
Npc Heavy Duty Organic Clutch
Apexi AVCR boost controller
Full 3.5inch zorst
Nismo Fuel Pump
Z32 AFM
Siemens 550cc injectors
Yellow Jacket Coil Packs
HDI Front Mount
So as you can see my car is capable of making some decent power just need the right turbo to do so.
Edited by DoseVader
it is wonderful that you came to this realisation yourself.
incidentally plenty of info from a search.
you are in fact all set for a sweet setup after highflowing your R34 'OP6' turbo
enjoy
enjoy
Can't be any more laggy then my current highflow setup, full boost at 5,000rpm thats living barry
Then you'd find the r34 hypergear highflow a blessing
I still need to sort my Pfc boost control setting out properly to get the boost right in the upper mid range, but it pulls nicely from 3500 rpm onwards, got 276 rwkw, power delivery is very linear and easy to drive
Good part about the highflow is it essentially bolts on, so installation is easier if you're doing it yourself.
Anyone feel free to correct me if I'm wrong but I thought the ss1PU is designed to be able to pull the same max power as the OP6 highflow with even better response?
Yes SS1PU is made to do the same sort of power as the OP6 high flow but with stock alike response, thats a very good option as well.
As mentioned earlier I've upgraded the intercooler on the R33 GTR from 600x300x68mm to 600x300x100mm. Using the same ATR43SS25 Alpha turbocharger, it managed to hold more boost on less boost controller duty, 10 degrees less in air temp, picked up more mid to top range, and the penalty in response is 100RPM.
By now, I have a good platform for turbocharger related evaluation and testing.
Also for few customers reports boost tappering issues on their RBs. Check your pressure drop across your intercooler. Some of you might be surprised of how much boost it actually restricts.
Below is a dyno log on a ATR45 using a return flow cooler, with customer defending for his 20 Cents junk.
Green is before cooler, and Red/pink is after cooler.
I found this issue with people using Blitz front mount and return flows also. If this is a scenario on your setup, get a tube n fin, 600x300x100mm cooler, we can supply that for under $200, and that has been tested and works.
+1, get the high flow - meets all your requirements and lighter on the pocket. I got the SS2 because I wanted a dyno queen LOL
Tell the truth Johnny you just wanted GAAAAAAAATTTEEEE! :D
Intercooler restriction. that car made identical amount of power using OP6 high flow, SS2 and now a G4 (3582 equivalent). They all can only be boosted to 16psi with actuator disconnected. Similar behavior to when I was using stock GTR33 cooler, this one is alot worse.
This is result from the Peter's dead T67 earlier, It is now rebuilt and high flowed running our ATR43G4 CHRA assembly, pulled 404awkws E85, fuel pump leaned out. Its now tested and ready for pickup. This assembly is good enough to pull around 430awkws with a new pump. I don't think I will be chasing for more power at this stage, But will be working to get better response.
Video added:
Told ya so Mark lol ;)
Hehe, that you did Mick. Been plenty of decent results with Blitz coolers before though (at around 250-260rwkW Mark), which was why I was wondering if the pressure drop is more noticeable at higher boost.
Anyways, thanks for posting those results Stao.
ATR43SS2.5 Alpha final run on E85, GTR-R33. made 367awkws on 20psi.
I've included dyno videos of the same turbocharger running both P98 and E85 fuel:
Fine, I'm not going to lie. I wanted gate LOL
Fek all those Honda homo vtecs, I has gate... Don't be mad :D
Exactly what I thought when I bought my blitz return flow, time for a new cooler it seems..
What cooler was it Tao?
Edited by owen1r
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
    • I _think_ that one has a christmas tree or some other retainer spike into a hole in that panel under it. Come in under it with thin scredrivers and just pry it gently up. If you rip the ears off the retainer pin....so what? Just stick it back down after with a bit of race tape and carry on with life.
