The 53mm GTRS turbines don't work with RB25det engines very well.
The SAT stands for Special application turbocharger. This one is made only for Rb26 and Rb25 turbo engines working with large external gate setups.
We can high flow them to -5 or -9 depending on the HP chasing for.
With the damaged -7s I need to have a look at the turbo, the smallest billet wheel that I currently make is in 60mm that made 250rwkws on P98 on my SR20det.
The -9 idea sounds the go, what's involved in that and can it utilise the billet wheels
Also an idea on pricing, PM if needed
I have also posted in the Kando thread about fitting the 20.5g TD06SL2 onto a RB26 manifolds in twin form
Car is going in for tune next week with the 21U highflow and I can't decide which injectors to use.
I have a set of S15 440cc injectors (cleaned and flow tested) or potentially a set of used Nismo 740's.
If the 440's are enough for around 260rwkw (keeping conservative AFR's and safe injector duty cycle) I'll use them. If not I have to shell out for the 740's.
Car will be running PULP.
Why not just grab a set of ID's/xspurts? They're pretty cheap and have a 725cc injector and have E85 capability should it become available near you. Not sure what a used set of 740's goes for but I'm sure the xspurts would only be maybe 100 or so more
I want to keep the factory side-feed rail for now.
The 440s will be at or above max to make ~260rwkW. Will do it, but will not have any of that safety factor you were after.
I guess that answers my question!
Hey,
Recently purchased the newer version of atr43ss2 (internally gated 17psi actuator)a few weeks ago. Vehicle has following mods :
Nistune
Dvs custom metal intake 3" with breather and returns
Factory air box with high flow panel
Z32
Braided oil lines
Jjr dump/front pipe 3"
Catco race car 3"
Turbosmart boost tee
Ngk-r BKR7E 0.8mm gap
Blitz return flo cooler
Nismo muffler
Nismo fuel pump
Id1000
Dvs jez tuned vehicle and was only able to safely make 230kw going from 18psi Down to 15psi.
Elimination tests:
Removed top of airbox and tune ( minimal gains)
Removed muffler and tune ( minimal change)
Checked boost leaks etc
Running shell 98
I'll get the dyno graph and other details when I pick up vehicle.
Dvs tuning advised may be the return flow cooler causing the issue.
Any advice. I'm stumped.
Check pressure drop across the cooler. I see this happens with certain model of blitz coolers. Also pre-load the actuator abit more.
Green is before cooler and the rest is after.
  • Like 1
Any idea on duty cycle at that power level?
That was about 95 DC at factory pressure, I have since upgraded pump and bumped base pressure up 5psi and car has since made 293rwkw with new rings and bigend bearings and HG on same boost level
95DC is not advisable, but I was trying to achieve something which I am 0.14seconds off :(
Edit : with the way I have my car set up it is very good on fuel and has got over 630km from a tank full
  • Like 1
Hey,
Nistune
Z32
Braided oil lines
Catco race car 3"
Nismo muffler
Nismo fuel pump
Id1000
Elimination tests:
Running shell 98
when you say 'safely' make .... was the engine knock limited?
  • Like 1
Hey,
Nistune
Z32
Braided oil lines
Catco race car 3"
Nismo muffler
Nismo fuel pump
Id1000
Elimination tests:
Running shell 98
3 things I see MIGHT cause you issues
1) JJR dump pipe ( this is a copy of the HKS item and that was never really much chop )
2) boost T will cause boost to tapper off
3) return flow cooler could be causing pressure drop, Stao has graphs of this from his GTR
  • Like 1
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
    • I used to do that (sills with rubber jack block).. ... then I got side skirts, and there's no way for the jack to actually work there, the jack pad itself on the jack is too big. Is the answer to use a... smaller (?) jack? Hmmm.
