Only if it's blocked.... Ive made 290kw with a blitz return flow.... I'd eliminate the boost tee first. My mods are similar to yours.
Edited by Badgaz
what size is the rear housing on the turbo? also that graph isn't that helpful...do they have one that shows rpm as well as afr?
Edited by Badgaz
Big ups for Tao especially for the Highflow and SS2 offerings. I've been running a 21U highflow now for almost 5 years.
The latest one has the ATR compressor housing with the latest wastegate and exhaust wheel design.
On a standard engine, standard exhaust manifold, standard intake manifold, greddy cooler & havoc hard intake pipe with a Z32 & 850cc injectors it makes over 300kw on pump E85 with 18PSI peak bleeding to 16PSI at the top.
But it's not the peak power figure that I love, it's the response and delivery of torque.
  • Like 3
or just a basic MAC valve and let your ECU control it (if it has the capabilities), there's no way a bleed valve can surpass an EBC which runs in close loop oscillating to control the boost.
  • Like 1
I don't think the advantages of a EBC are drastic enough to correct a ~50rwkw deficit.
My TurboTech made 270rwkw no worries at 19psi and held it perfectly on an OP6 highflow.
  • Like 1
I do agree, but if he is looking to replace the boost tee as a possible source of power loss then I think he should get an EBC whilst he is at it. There are many advantages/features in running one.
Edited by owen1r
Hey tao how much is your Hypergear ls20.5g? Is it best run with a external gate and good high mount manifold? Or is there a bolt on version you make with stock rb25 6 bolt rearr.? Id probably prefer a vband rear. Make the price with the lines and whatever else ill need? Will it make 330-350kw at the wheels on e86/wmi and 270 ish kw on plain 98? Also how good does the adaptronic go compared to the likes of Vi-Pec/Link/Haltech ect in plug/play versions ofc. What can you do the Adaptronic for $$$'s wise with the sensors ill need and everything to just plug it in and set it up to go haha
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
