My latest dyno run:
After adding in an addition 6 degrees of timing up top and about 4 in between 3900rpm and 5400 rpm the motor refused to make any more power. Ended up making 327kW but I was leaning too much on the timing so scaled it back and she made 325kW E61
If anyone is interested in the logs, I'll e-mail them to you.. can't seem to attach CSV files.
And here's a short video of 3x cars I tuned that morning (including touching up my own, ignore the AFR readout on the S15 as it runs blast pipes)
Hey Stao, how is the new version of the SS2 different, and how much time/cost would it take to upgrade mine to the new spec (If possible)?
I'm hoping I can keep the turbine housing as mine is modded for the external gate, if its too much of a hassle I'm more then happy with the way it performs now, more just curious about details on upgrading
is that petrol AFR or E85 setting ?
E61, wasn't planning to put it on the dyno but I had some hire time left so pumped the 98 tank with E85
Some updates. This is from our High flowed 21U R33 turbocharger. It is currently a prototype.
It is currently fitted to my R34GTT, car made 287rwkws @ 20psi, full boost in 3500RPM. P98 fuel.
  • Like 1
How do you expect this latest high flow prototype to compare (in total power and response) to a HKS GTRS turbo?
The GT3071 version? probably similar
On paper this is about the same as an SS1PU. stock manifolds, internally gated. P98 fuel
I love the response of the GTRS ~ With my setup I have 5 lb at 2000 rpm and full boost at 3k.
But I realise the technology is getting a little old now. I'm wondering if there is a billet wheel turbo that has the same response but will give more power through the rev range.
Car got tuned - Tuner wasn't very happy with the IWG/Actuator so I'll PM Stao about this later. Tuner said he can get a wastegate performance graph for me to send over.
With that said I'm very happy with the turbo and the power, comes on well holds you back in the seat drives great.
5295311E-1770-4210-9BE2-8E9CF17A231F_zps
Edited by kingtube69
I reckon drop the cat and re run the car, there's probably some restriction in the system.
When I modded my cat back and introduced a resonator and a mid muffler (both straight through) I noticed a slight drop in response. Even on the dyno it a few weeks back I noticed a slight drop in response coming onto boost, even though I loaded it up at 3k rpm before starting the run.
Going to redo the turbo back when I redo the turbo setup.
  • Like 1
that car is running return flow cooler. He actually made within 1kw of my result when I did return flow evaluations. Drop exhaust and PWR cooler it should be sitting around 330rwkws mark.
Thanks all (Stao included) It goes for a retune early next year for e85 so I'll get it looked at then. What are the options for a more free flow exhaust? Would decat see some gains? Does anyone know how PWR compares to Plazmaman?
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
