  • Replies 219
Aiming to get back to the dyno the weekend (or Friday) after the easter long weekend.
Guilt, will you be free sometime around then?
I want to wind the boost up from 17PSi to 19PSi also. Hopefully then with a bit more boost and the hi flow cat, it will crank out ~300AWKW.
It will be interesting to get a power run done on a Sydney Dyno down the track to compare results.
How did the dyno run go Bakes?
Due to Paul having to go to Qld for work I took the car to Sydney to get it final tuned. Car got tuned today by Scott at Insight Motorsports. Ive spoken to him over the phone, it made 396 Horsepower (295Kw) at all 4 wheels at 1.3 Bar.
This is with my 19 inch Volks on also so with stock wheels it will pull 310-315 All wheel Kw. Im looking forward to driving the mofo.
Ill post up graphs when I get them.
Why would it make more power at the wheels with the 18's ?
of all people i thought you would know this dude... unless you use a hub dyno.. the size of the wheels and friction properties of the tyres will affect the power output on any particular dyno.. high reading or low reading.. his volks have a rolling diameter of 675mm while the original gtr wheels are 654mm, so the original wheels will give a higher speed reading and slightly higher power reading. the big wheels will give a higher torque reading and less speed.. it doesnt matter anyway as the dyno was just used to tune it.. scott @ insight said it has got more to offer and its a very safe tune for day to day driving.. and its been tuned for maximum low down response... not top top end power.
regardless of power readings and dynos and crap thats gone on and what anyone thinks.. this car now hauls. it has fantastic driveablity, excellent fuel economy, and power to boot.. for the amount of punting bakes does.. the money has been spent, the parts are fitted, and the result at the end are what matters, it should keep him happy for a while..
simon, if your not content with anything about bakes gtr, feel free to line your r31 up anytime you like (or your mates mp3 player) .. until then.. let him enjoy his car stop worrying about what you could have done for him..
Car made 400HP at 4 wheels but was pulled back a bit on final tune to keep everything nice and safe (stock motor) Not running crazy boost either. (only ~1.2/1.3 Bar)
The tune is fantastic, runs so smooth. Tuned for cold start also, Im very happy with it. Ive found no need to give it more than 70% throttle yet either, she goes pretty good ;)
Here is my performance mod list:
* HKS Front pipe, HKS rear pipe with Hi Power Muffler, Hi flow cat
* Garrett 2860R-5 Turbos
* HKS SPL full piping kit with HKS super power flow pods
* Nismo Fuel Pump
* Turbosmart fuel regulator with pressure gauge
* Hypertune Billet fuel rail
* Siemens 610cc Injectors
* OS Giken Cam gears
* Nismo twin plate clutch
* Vipec V44 ECU
* Tech Edge Wideband AFR controller
* HKS EVC6
Tune results at different boost settings on Insight Motorsports Dyno, ALL WHEEL HORSEPOWER: (19 inch volks on)
Now for those interested I had some fun with excel to compare my results from where my car was stock except for exhaust to where the car is now:
Notes: Above dyno graph is in All Wheel Hosepower, the graph below I made is in All Wheel Kw
: Blue line was done on IS Motor Racing Dyno with stock wheels/tyres
: Yellow and red lines are on Insight Motorsports Dyno with 19 inch wheels
My biggest loss in response is ~ the 100Kw mark with a loss of ~550/600 RPM. The -5s catch up ~ the 4400 RPM mark
Would be interesting to do another power run now on the IS Motor Racing Dyno.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
