  • Replies 192
i am getting a set of the upper arms for the fornt and may get some rear arms
i could lift it one click on the ohlins i guess which would raise the old girl but that reakes of effort
i always shift at 7k in my rb26 powered cars.... probably why i dont duncan them all the time
the rb30's shift at 6200 as they have heaps of grunt down low
doesnt make any more power after 7 anyway.... my r31 which had a 3540 i shifted at 8k but it had grunt and forged things inside it!
:D
tell the truth. you shift at 7 cause you are flat out gay. you like the company of men. hairy ones with presents for you.
still can't deny you are a good looking bloke and have a toit body. yesh toit.
turbo is shit too. made heaps of noises when it was banging around loose in the boot of my car. at one point a spanner i had lying in the boot got jammed into the compressor wheel and when I pulled it out the farking head of it was gone. if you find my spanner head in your turbo, engine or cat then kindly post it back to me you cnt as without it my spanner is about as useful as your tiny penis. thank you.
It sounds to me that you are some what jealous he's with men that are not yourself Baron????
Rhys
  • 3 weeks later...
